Real world hp for ECU tune?
I ask because you are an 06 to
.as for the ecu tune 50hp from ecu alone seems high!!! from what others offer
also did'nt a few users mention that the k&n filters were no good on our cars?
something to do with making the engin bay hotter if i recall due to the design
?or was that on the M cars
can not remeberThis is such an old topic. Thanks to Vadim for clarifying a few things for us. It all comes down to the extent of modification that you have. Having a stock car and spending $2K on an ECU tune, looking for hp is just not the right move. Now, once you've modified it to where it is out of the ECU's sweet spot, then you will clearly see gains.
To the guy that said 155 is enough: Sorry, dude. Mine goes to 160 and it is NOT enough.
Another topic:
I still have not seen ANY gains from an ECU tune on an '06 built in '06 E55. I would be extremely interested, if any vendor has it (dyno sheets) and can prove that they have control of he appropriate parameters.
Welcome to the forums...
To answer your question, I think Vadim already answered this up on post #11 on this thread... Stating that you can tweek another 3-4 RWHP with the 93 octane fuel... This seems totally inline, and I have no reason to doubt his numbers.
Best,
RoydRage
Now I'm not insinuating that... BUT, I know one thing. I don't believe 50HP from software alone. And if a car with an ECU tune alone beat a car with an ECU tune AND a Pulley,(something that will really build HP by building boost), than that car might have had a bad IC pump.
I've been racing Motorcycles since I was 9 years old, and cars since I was 16. I have built more race motors than I can count. I am an award winning NHRA "PRO" Class Drag Racer, I have Road Raced Bikes, Motocrossed, I have gone 7's in the Quarter mile, more importantly I've built all these motors, And I can tell you I *REALLY* Doubt 50hp from software.
I motor is an air pump, nothing more... You make HP by getting Air Into the motor, and getting it out more efficiently. You do this... By forcing more air in; Supercharger/Turbocharger), Porting cylinder heads, increasing Volumetric efficiency, (combustion chamber shape, Increased spark, etc), Larger throttle body/Carb, Camshafts... This works by increasing the amount of lift at the valve, and Keeping the valve open longer through the stroke, but also makes the car very peaky, and ruff running at low speeds... Why? because you are over rich at those low speeds and have a contaminated intake charge...
Optimum intake charge speed is 275fps. Now when you port and make a surface area bigger, velocity goes down... the only thing will increase it again is RPM/Volume, that is why porting goes with Camshaft profile.
Cams increase power by having a supercharging affect, but this only works at high RPM because with a long duration cam you are keeping the Intake valves open as the Piston approaches TDC on the power stroke, Now at high RPM this works because the fuel has so much velocity, It keeps cramming itself into the combustion chamber even though the piston is trying to push it back out! BUT, at low speeds the piston does this, and the fuel charge goes back into the ports, and often plenum getting re-richened. Also exhaust can get back into the combustion chamber at low speeds contaminating the intake charge, that is why wild cams run ruff at low speeds.
Now along with headers, and exhaust mods that aid in getting spent fuel out of the motor, and help evac the combustion chamber making room for more fuel/air, and purifying the charge, these are some of the things that really boost HP.
Now what I guess I'm saying TUNING alone can account for a slight improvement. Vadim claims 20hp... This it totally believable... 50HP? NO!
Guess what? AMG just AIN'T that bad! How much can you push engine ignition timing and fuel curves? The cars are rich enough stock, so you advance timing, and lean it out till what? You have a hole in the piston?
AMG when building a motor will push those parameters to a level they feel safe with for long term reliability, now is there margin in that? Yes, but they would not throw away that much power, I assure you they're no dummies.
Now I was happy with my Evotech tune, it took away the bad affects of the MB IC pump relay campaign, and gave me a little extra... Something I could feel which thrilled me, so I posted about it... Even there Ingenere had to come on my post, and push his stuff... Do you seed Adam, or Vadim continually doing that? No... They post to help people... All this guy does is (who is a chiropractor), is continually advertise, and push his ECU tune all over these forums... and I'm sick of hearing it, In my opinion his claims are unrealistic, and I don't want to get continually beat over the head with them.
Sorry, but I had to call him on it.
I love this forum, and I like a lot of the people on it... The E55 threads especially... all you guys are devoted, and really into this, and I applaud, and appreciate you!
Best Always,
RoydRage
Well said RoydRage.
Just as an example - on Bentley Continental GT, I can add 80HP with a simple software flash. From 550HP to 630HP in less than an hour.
I runned my car against same car Evotech E55 and Evotech SL55 and Kleemann K4 with 11.5, 12.0 and 12.2 AFR at WOT...and I can tell you that btw 12-12.2 there is differnce and you can feel it...
Before Evoetch E55 would catch ME and pass ME in 1/4, Kleemann K4 would run dead even with 11,5 mixture...My chip tuner have been runing safe...
Then we tried 12.0 and I spanked K4 car in 1/4 by 2 cars and runned dead even but still beat Evotech E55 with track slicks and 18 wheels, I have 19 wheels with 285/30 tyres...
Now I run 12.2 mixture nd I actually start pulling on SL55 with TCU EGS done at higher speed, before he would start to catch up with ME...
Now I have installed IC mod and Airbox and tubes and going to adjsut ME ECU again but not sure HOW...cause with IC mod I could run leaner but with more air to motor for airbox and tubes, I need more fuel also...
We going to test tommorow...
boost
a/f ratio
any others
were the numbers russ was referring to a/f ratios with the 11.0 12 etc
Given we change boost from stock levels ECU sees higher boost and goes into proteciton mode dumping fuel... so you go pig rich and power is poor and lumpy ....
I can quite easliy believe that a proper leaned out from a pig rich scnerio on a E55 can result in big differences... the difference being that timing is being pulled in one instance with as well with too rich a mixture and in the other a better mixture with no timing being pulled can easliy translate into 50hp in my opinion....
In a E63 you can only advance the timing as IAT's are constant as there is no F/I ... you can only go to the knocking point and back it off a tad from there - nothing more you can do on the N/A motor with ECU. The F/I has more variables that come into play and each can be programmed in a way not to rob you of power and with higher boost leverage off it, as in stock form the E55 runs rich ...
how about this ...
boost
a/f ratio
Ignition advance / timing
IAT repsonse vs mapping
S/C enagement points
BTW I think above 12.2 you are getting a little lean on the FI motor and would only run premium fuel with this AFR.
A 12.2 AFR with race gas could be a killer combo ...
Wanted to try VP Racing 106 or 116 Racing Gas (fully syntetic) but the guy who sells it told ME it wondt work on my car and said better get NOS octaine booster...
There is usually about a 10-point delta between the RON + MON numbers, hence the ~5-point delta between Euro and USA octane ratings.
there's no need to run that high of an octane by using straight race fuel but you can mix it to increase octane. just make sure it's NOT leaded.
http://www.omegamotors.com/enjoy/gas...soline_06.html
We measured the boost and its at 0.98 (which is about 14 + Boost) this got ME thinking is ASP pully if 15PSI pully and I have Wrap Kit how come my boost is lower at WOT...Does it mean that my elt is still slipping
I spoked to my VP Racing fuel dealer and he said it wont make any diff on my car and also I have drown the fuel tank, if I mix I could hurt my engine...I my chip tuner said not to do it, cause we dont know how it would burn and what AFRs would be then...
So I am a bit cinfused and sacred to use Racing fuel but still wanna try it...
I dont know yet, may be I should jsut use 98 BP Ultimate (93 US) + NOS COctain booster which increases boost up to 6 numbers...
So yes if RON is 98 , MON is typically 88 , so 98 Euro is 93 US. 98 Is preatty easily available in UK / Eur ... whats the best freely available in US?
In most places ouside of the West Coast, 93 is the top grade. In some major markets, due to smog, oxygenated or reformulated with oxygenate is required. While the AKI remains the same, mileage and energy-per-volume is down due to use of ethanol.
Just one of the many reasons to use a local tuner, if possible. Hell, just going from summer to winter blend makes a difference, if you're running on the ragged edge...
