Adjustable air ride system to lower the car
Old Oct 12, 2007 | 05:43 AM
J.Seven's Avatar
Porsche 996 (300Hp) Powered Boxster/ Audi A6 Station Wagon
Has anybody use this produt here?
Cost is 222$-250$ and you can choose how low you want to go. According to they site it doesn´t take more than one hour in labour.
Would like to hear some feedback from those who have use it.
http://www.adjustableairride.com/
J.Seven
Old Oct 12, 2007 | 10:11 AM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
I have them on my car for over a year now. They work great!! Front is very easy to install. REar is very diffiucult if your not handy. I assume its an E your putting them on?
-Walter
Old Oct 12, 2007 | 10:19 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Do a search, I think you can do the same thing with washers for $1.00
EDIT
Here you go 101 posts "How To"
https://mbworld.org/forums/showthrea...asher+lowering
Old Oct 12, 2007 | 10:49 AM
komp55's Avatar
ML550
I've read through most of the discussions on the topic on this board. Summarized, the most common alternatives written about are:
1) use Star Diagnostic system $$$ (dealer method)
2) Chinese washers $ (Home Depot method)
3) TWS brackets $$$ (don't know if they're still available)
3) Fancy washers $299 (Altered Atmosphere method)
4) Mechanical links $249 (Adjustable Air Ride method)
5) ELM module $,$$$ (various tuner method; e.g. Renntech, Carlsson, etc.)
All methods have positives and negatives depending on your lowering objectives and factory warranty retention concerns. For me, the adjustable mechanical links seem like the best choice since once I've attained the desired ride height and rake for the car, I don't find the need to constantly diddle with it. Plus, not having to splice the air ride control harness protects that aspect of my car's CPO warranty. Others will have other priorities when making a choice; you pretty much can't go too far wrong with any of them, and your car will look better sitting a tad lower toward the tarmac.
Old Oct 16, 2007 | 02:21 AM
tommy25000's Avatar
2005 E55
pros and cons for Renntechs VS mechanical links?
how do these handle slammed?
Old Oct 16, 2007 | 09:53 AM
Sunny55's Avatar
2005 SL55 AMG
J.Seven
These are actually the lowering links that I have on my car. I didn't do the install myself, but the guys that did all the work on my car told me they had to put the car on the lift and put the wheels off and on at least 4-5 times to get the desired lowered height. The rear of the SL in stock form is much higher than the rear. Since these links are only manually adjustable, you have to tinker with it a few times.
I didn't want to cut into the airmatic wiring. And this saved me a few bucks. The raise button still works the same, as well as my ABC. All this does is trick the computer into thinking that your car is higher now, due to the fact that these links are longer than the stock links, and therefore, your airmatic will automatically lower the height.
So far so good for me. My car is pretty low right now, and I did notice the ride to be a tad more bumpy, but when I raise it to setting 1, it's fine. I say, go for it! Good luck.
Old Oct 16, 2007 | 10:58 AM
Big Carrot's Avatar
CLS 55
I put them on my CLS a few weeks ago, and I've been very happy. They are easy to install, easy to adjust, and easy to take off if you want to go back to stock. Plus, you don't have to jack with any wiring, and they cost a lot less than the module.
Old Oct 16, 2007 | 11:05 AM
jangy's Avatar
2015 S212
The ELM simply has more flexibility. For example, it becomes a real treat IF you modify it so that it can be mounted and accessed easily. You can tune the height to meet your mood. You can also turn the unit on or off at whim (for service for example). As for the splicing, yes it is a concern, but all you need is a piggy back harness that fits between the airmatic unit and its harness. Easy to make and probably cost about $100, max.
That said, many people love the links. I had made my own set at one point and I have to say they were fine.
Old Oct 16, 2007 | 02:55 PM
Cosm's Avatar
2016 S550 designo Magno Cashmere White (Matte Finish)
Why they gotta be CHINESE WASHERS ??
Old Oct 16, 2007 | 08:50 PM
komp55's Avatar
ML550
Cause that's where Home Depot sources its washers. Any steel washers will do.
Old Oct 18, 2007 | 04:26 AM
John V.'s Avatar
Former Vendor of MBWorld
2007 CLK63 Cab
Thanks everyone for the nice posts!!!!
Easy installation and adjusting was very important to me when designing them. I know the E and CLS rear link is a bit tricky the 1st time but after a couple attempts it's a breeze. I can do it in about 5 minutes.
John V.
