*** VRP Crank Pulley ***
#51
AMG engineers are not idiots' the have an reason why the build the pulley like 2 Pulleys with an rubber damper in between to keep the force away from the crank and keep the SC Gearbox ......
and 2 Belts strait on 1 damper will make an strange Frequency on the crank.....
#52
2003 E55 AMG
Here is some more data on our new pulley:
- Stock pulley is TUFF bonded by vulcanized rubber.. that's it.
- In comparison, some of the aftermarket pullies are pinned at different points around the circumference.
- Our pulley has 2 carbon steel pins that are preseed into the solid mounting section which are harder than the alloy pulley itself. The rest of the mounting is done by stainless steel hex bolts.. From what I was told, the pulley would disintegrate before the mounting hardware would.
- Torsional energy is absorbed via the accessories pulley and counter weight which is mounted on rubber
#60
2003 E55 AMG
Forgot to mention one thing...
Anyone who buys a crankshaft pulley has an option to add our underdrive pullies for an additional $250!!!!!!
Here is a pic of our billet aluminum 3 piece underdrive pulley set.
#64
Looking good Victor...e-mail sent...
Hope to see to Dyno results on those pulleys:
1st without underdrive pulleys and 2nd with underdrive pulley...
Will this underdrive pulleys work with my ASP pulley and wrap kit or I dont need it ???
#65
2003 E55 AMG
Guys.. just an FYI.. Pullies are being packed and shipped out next Tuesday..
If you are on the list please and have not already done so, please make sure you email me your paypal info so I can process the orders.
Thanks!
Thanks!
#66
Glad to see you got rid of those ****ty button head bolts!!!!!! had a friend of mine with them on a set of adjustible cam gears that loosened up and timing advanced, and well lets just say the inspection hole in his block was not pretty! you can certinally put more torque on a standard allen than a buttonhead!!
#67
2003 E55 AMG
It was a prototype piece that had those bolts...
Glad you like them!
Glad you like them!
#68
2003 E55 AMG
Those red pulleys look <PeterGriffin> Freakin' sweet! <PeterGriffin>
I haven't heard of the underdrive pulley thing, care to educate me?
Now, off to find that pulley thread!
#69
Super Moderator
#70
S600TT, R350
Victor, does that $250 price tag for the under drive pulley's apply to the holiday special you and vadim are running also by any chance???
#71
2005 E55
#72
2005 E55
