E63 Rotors on an E55?
Which Poterfield model did you get or do they only make one model for our cars. Hows the brake dust less than our OEM pads?
also we deal in KG's here so any one know what the conversion would be in kilos?
also what it would work out to when driving, interims of weigh saving?
thanks
The difference in feel is huge, simply because it is not just weight, but unsprung weight. Every time you speed up, slow down, turn, or make any shift in momentum, that weight comes into play. Consider a gyroscope and see how much easier it is to manipulate when the weight is dropped.
The difference in feel is a crisper snap when you hit the pedal. It basically does not need as much effort to get better grip. Also, after some hard driving, the OEM setup would throw a heat sign up and the brakes would fade just a bit. I have had no fade at all with the Rotors and porterfield pads.
