New Custom Front Mount IC HE (2003 E55)
Old 11-28-2007, 09:43 PM
  #126
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by Code3 Performance
...In low flow rate applications, this would not be a huge issue (>12lpm). But in a higher low unit, like the CM30, you are pushing 26lpm.
while there's plenty of flow from the cm30, imho it's likely not going to push those flow rates in our systems...even with a bar/plate style heat exchanger.
Old 11-28-2007, 09:48 PM
  #127
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
............... the internal fins are called Turbulators. ................
...theeeeese must be up-graded
BRANDON, here WE NEED ALL YOUR SCIENCE
Old 11-28-2007, 09:51 PM
  #128
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Is this thread going to turn into the "Group Buy" thread?
Or do we wait to see the vrus and code3 side by side?
Old 11-28-2007, 10:05 PM
  #129
dyno's Avatar
GB # 500 ?
even if don't need, I'm in as HOMAGE to ART
... and STIMULUS for final GOAL
Old 11-28-2007, 10:16 PM
  #130
TA-DAAA
I could be wrong but the SLR coolers retail for $7K each.
Be nice to see an after market equivalent for $5k a pair
Russ, Brandon do you think it could be done.
Old 11-28-2007, 10:33 PM
  #131
dyno's Avatar
?? .. any SLr cooler needed
only opening our baby ...and improving its TURBULATORS
Old 11-28-2007, 11:17 PM
  #132
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
I have measured the flow rate through my C32 system with my heat exchanger. One side was emptied into a gallon jug, while someone else was refilling the tank (I had the system separated at the time). We measured more than 5 gallons in 60 seconds. That is 18.9lpm+. This was using the CM30 pump. It could have been more even as I was swapping jugs in and not always getting all the water lol. It was very scientific
I will start a new thread soon. As far as seeing them side by side, I think most of the information is available between this thread and his sale thread for someone to make a decision.
SLR coolers. Well I have seen the pictures, and certainly think they are feasible. I think I will give Victor a call on that one and see what we can come up with
Old 11-29-2007, 01:17 AM
  #133
phatmitzu's Avatar
2005 E55
thanks ... but was curious to see how it fits on right side to the radiator
Doh...
I'll remember to take some pictures of the right side the next time the bumper is off (soon).
Originally Posted by TopGun32
now go on and take on the 335 that was talking smack..
Hahaha...you know it!
Originally Posted by stevebez
Hi Brandon ,
I think the results you published are very interesting but do you have the results of the OEM H/E to compare with?
I would also like to see when (if at all) IAT's plateau and at what speed this happens ...?
Brandon, we can find a weekend to do this. Swap back to my stockers and get some numbers.
Old 12-01-2007, 11:36 AM
  #134
Just an update as I have many people asking what is going on.
I am waiting on all of the oil brackets from Mercedes. Because of the large order, they had to source them from numerous places.
Tomorrow morning we are going to do some more datalogging. We are swapping the stock HE back on for some data. Then we are putting the Code3 Performance HE back on, along with the Johnson pump for additional data. This will give everyone some good solid data to compare.
There was some confusion as to the retail price of our heat exchanger. The price listed on our website was not the retail price, and was meant to be a sale price. I did not realize that it did not say that. Because of the confusion, I will still be listing the units with a small discount from that $699 price, and offer free shipping for a limited time.
Old 12-01-2007, 09:02 PM
  #135
dyno's Avatar
thanks,
we need threads that come to an end with some clear evidence
Old 12-02-2007, 01:42 AM
  #136
jangy's Avatar
2015 S212
All sounds good. When can we expect to get the units?
Old 12-02-2007, 04:55 PM
  #137
psk145's Avatar
2006 E55
so whats the price? Less than $699 delivered
Old 12-02-2007, 08:31 PM
  #138
TopGun32's Avatar
yup.. $699 shipped, plus a few bucks off.
Brandon,
you should do a group install.. for a handful of so Cal cars and nor cal cars.
suggest:
small sticker to place on the FMIC..
Old 12-02-2007, 10:59 PM
  #139
phatmitzu's Avatar
2005 E55
Swapped back to the stockers and did some datalogging... Numbers wont lie. I'll let Brandon post them. All I got to say is now I know why everyone say a cooling upgrade is a MUST for pulley'ed owners, especially the ASP.
Here are some photos I took after we swapped back to the Code3 unit. Again, please remember that my unit is the PROTOTYPE with custom mounting brackets. The production ones will have OEM direct bolt-on brackets.
Dyno, is this what you were asking for? The right side of the HE?
Old 12-03-2007, 12:40 PM
  #140
TopGun32's Avatar
I drove my car for close to 9 months with ASP pulley and stock IC... I was missing out on all the fun....
and probably was performing worst than stock.
I can already see the ITA's spiking to 170 to 180 all the time..
Old 12-03-2007, 01:28 PM
  #141
phatmitzu's Avatar
2005 E55
For sure.
The first initial run with the stock HE, the ITA spiked up to ~230F... and that time I didn't even get to go pass 100mph due to traffic.
Old 12-03-2007, 02:10 PM
  #142
Ok, here is the data. Thanks to Mark for spending a long day putting up with me
We swapped back to the stock heat exchanger for the sake of data. I am sure there are numbers floating around somewhere, but we really wanted to get some numbers on the same car, same mods, similar conditions. For comparison to the other graph, I posted it below. Stock pump was used for both tests.
The outside temperature was 65°
The two runs were 3 minutes apart again.
First run to 112mph (sorry, traffic), second run to 119mph.
IATs spiked to 181° on the first run (112mph), and settled to 140° in three minutes.
IATs spiked to 230° (119mph) on second run.
Before we started the first run, we drove until everything was warmed up, and we could get a baseline IAT number. The stock heat exchanger kept IATs around 30° above ambient during normal driving.
I will post our ad this afternoon, and update the website pricing.
Old 12-03-2007, 03:17 PM
  #143
JAYCL600's Avatar
new balance
sounds abnormally high relative to ambient, did the supercharger disengage on this run?
Old 12-03-2007, 03:31 PM
  #144
psk145's Avatar
2006 E55
am I reading it right, or is it a 50 degree change in temperature when the car is just cruising between the stock and code 3?
Old 12-03-2007, 03:42 PM
  #145
TopGun32's Avatar
ASP pullies run hot!
its those 110+ runs ....
the difference between stock and bigger FMIC on those pulls is the key.
Also notice how long it takes to cool down compared to the Code3 unit.
With a slightly better pump and better water mixture + water wetter would be see a slight improvement over the stock pump/coolant set up.
with a stock pulley.. the difference won't be as much, but definately would see the ECU pulling back as well.
thanks Brandon!
Old 12-03-2007, 04:46 PM
  #146
dyno's Avatar
Thanks .. and sorry for late reply but was busy with all that pulleys
but, did you take them by phone ?
See where is the question mark in Evo add on application: in Code3 replacement application, therefore that blaack plastic and adiacent stock He no more exist. right?
Old 12-03-2007, 04:48 PM
  #147
phatmitzu's Avatar
2005 E55
Not that I can notice. It did had a rough jerk when I let off the throttle though
Old 12-03-2007, 04:50 PM
  #148
phatmitzu's Avatar
2005 E55
No, I took them with my Sony T9
Yup. The code3 REPLACES the stock HE. No more stockers.
Old 12-03-2007, 04:59 PM
  #149
dyno's Avatar
mmh, .. not in all.
seems to me that till end of 1st pull it was that better
but it's strange that after 2nd pull it was not good the same
Temp didn't lower that much even after enough time and low speed
in any case, results seem good
for BRANDON:
btw: - pulls were on same gear?
it's a pity that test wasn't made trying to keep same comparable speed
.. we could avoid one parameter and overlay curves on a single graph
now I'll do some copy and save for memory
ps: I'm having the idea that outside temp in LA is ... close to Sahara please, how much it normally is in spring and summer ?
Old 12-03-2007, 05:03 PM
  #150
TopGun32's Avatar
i get the same effect.. after a hard WOT run...
not sure what it is. Engine or Transmission?
Quick Reply: New Custom Front Mount IC HE (2003 E55)
