First Time at Atco NJ with the E55
Maiden voyage down the track tonight. temp was in the low 50's high 40's.
air was nice. Only good run was 12.36 @ 115.93. 60' time was a 1.99 this was with regular continentals. Not bad.. Car is 100% stock.
05 E55 Brilliat Silver, My 05 Gallardo Silver
Nice run and good time , did you have traction control on or off? did you build the rev's up?
I am willing to bet that you killed your launch by running with tire pressure that was too high and/or not being patient with your launch. If you practice your launches and learn to let the idle torque launch you out of the hole, you will shave 2/10's off that time easily.
Again, nice job.
https://mbworld.org/forums/showpost....7&postcount=38
Don't want to hijack the thread, so here is the link to my post on how I launch:
Nice run, especially for your first time.
Again, nice job.
Again, nice job.
Do you mean exalirator down to the floor and let the car work it out?
also what psi or bar should i be runing in a cls for streets?
The car sat and cooled down for about 2 hours.
I pulled around the water the best i could. did a moderate burnout.
Traction Control off left easy about 800 rpms. car spun alittle and eased into it. it pulled hard so it was hookin. But need drag radials.. (1.99 60 ft time.)
Tire pressure 28 in rear. 34 in front.
