DIY IC Pump E55
DIY IC Pump E55
Hello Gents: As the E55 is getting out of warranty now we will have to start doing things ourselves so lets start the new topic. DIY Everything and lets share.
The first thing I would like to do is replace my IC Pump or maybe just the coolant. (Old subject - New Request)
Does somone have the pictures and the whole process of doing the change??
How do you refil the cooling liquid.
Is there any way of checking the Cooling liquid or repacing it. What is the procedure for replacing the cooling liquid.
Cheers....
Cheers....
I replaced my pump over the summer with the latest version. You don't need to drain the coolant. Get yourself a set of hose pinch pliers and that will save you time and mess.
Get the car up on ramps, remove the front engine cover, pinch off the coolant lines as close to the pump as possible, remove lines, remove pump, install in reverse order.
Bleed the circuit from the capped nipple using a clear hose so you can see when there are no more bubble in coming out. Just like bleeding brakes. It's that easy.
Does that mean there is no separate cooling system for the intercooler? Both the Radiator cooling system and IC Cooling system are one?
If yes mabe I sould replace all the liquid for better performance as the ambint temprature in KSA is 104F
Alsalam
let me know what you decide on as my country is hotter
1 Post
2004 S55 AMG
Sure...I actually left that out...oops. In order to bleed the line of air the pump has to be running. I disconnected the pump plug and took two very small alligator clips which I ran one from a 12V supply to the + pin on the pump and just grounded the other one. I energized the pump for about a minute or two until no more bubbles came out in the clear hose. After that I pulled off the hose real quick and put on the plug.
Make sense?
Make sense?
2003 e55
E55
Thinking of tackling this myself- how crucial is it to bleed the system afterwards? Could you turn on the car after the install and let it idle and keep the reservoir open for all the air bubbles to come up to the top? Everything looks straight forward except for the bleeding process....
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
The bleeding process is a piece of cake but I find it takse a few minutes to get ALL the air out. Also, I have typically run the pumps of either a small 12V battery, a booster pack, or the trunk mounted battery (using long wires) to run the pump for bleeding. Going to the fuse box just seemed like additional brain damage to me.
You don't even need to do that the ic pump turns on when you start the car (except on cold starts)
In other words it is pointless the wire the pump so it stays on always.
Can you hear the intercooler pump when it is running?
I was just about to replace my ic pump, but once I got the (old) one out, I realized it was the newer, updated pump. I reinstalled it and tried bleeding the system. I used a clear hose attached to the top cooling hose and left the reservoir cap off. A bunch of air appeared to have escaped, but I did not hear the ic pump running after starting the car or shutting the car off. Should I be able hear/feel the pump while it is running?
Thanks,
Steve
Thanks,
Steve
well with all the engine noise it maybe hard to hear the pump running. also can you tell me how did you know the stock IC pump was the updated design.
2004 E55 AMG
If the pump was running, it should continue to run for about 15 seconds after the car si shut off. I don't know if you can hear the stock pump, but the CM30 is definitely audible. I drive the car around for a couple of minutes and got into boost a couple of times, then bled the system. You can also just remove the rubber cap from the bleeder slowly. If coolant starts to come out at a decent rate then the pump is running. Remeber, it isn't a pressurized system(unless the car is hot and the radiator cap is on), so coolant will not spray out under pressure even when the pump is running.
GreenStar (04-09-2019)
Hello Shardul,
I think it is the latest revision of the pump as it has the part number 000-500-03-86.
The pump should stay on after a hard run for 10 seconds? Do you need to shut it off immediately to bleed the system?
Thanks,
Steve
Thanks,
Steve
C218 CLS63TT PP Edition1, W213 E63S
i did it by myself also
it took my an hour, but the problem i faced that i was searching alot for the resovior of the S/C cooler, and then i checked the one on the driver side, saw it was low, filled it up after removing the nipple and air was going out.
i kept it half an hour untill air was removed.
however, i noticed one important thing
after couple of days driving, it gave me coolant water is low, i double checked th I/C if there was a leakage but i cdid'nt found anything. so i refilled the coolant again and after 1 month , it is still full.
so i think there was more air that went to the resovoir after several times driving.
so yes, air can go to their, but will take long time.
regards,
regards,
I read here on the forums that there is a complicated procedure for the MB techs to follow to bleed the system properly after installing a new IC pump.
Do you think there will be air trapped in the system that we can't remove from just unscrewing that one bleeder cap?
Thoughts?
Thoughts?
Thoughts?
Thoughts?
for me the best way to bleed it is connect it to a 12v source. do it first thing in the morning so you dont have hot pressurized coolant all over your engine bay.
