6.2L engine info
Old Nov 18, 2007 | 04:03 AM
XRQTOR's Avatar
2014 ML63
6.2L engine info
Old Nov 18, 2007 | 04:24 AM
Fantasm's Avatar
Car Whore
6.3Li?
Old Nov 18, 2007 | 07:23 AM
Zax63's Avatar
2006 s65. Ford Excursion 6.0. Pontiac GTO convertible. Porsche 944 Turbo SCCA car. Wife-E550 and 968
Fantasm, MB calls it a 6.3 for nostalgic reasons, it is really a 6.208L
Old Nov 18, 2007 | 11:54 AM
pcalver's Avatar
2007 SL550 - Aegean Blue; 2008 E63 Wagon - Iridium Silver
Google work for you? Does for me.
Old Nov 18, 2007 | 12:02 PM
intellilogic's Avatar
'12 E350 Coupe (3rd Benz)
I think the engine in different models is actually different litters, I think it was the same with the 55 - in like the SLK it was like 5L no super charger or some ****... I think that the engine might be 6.3L in the biggest model of car with the highest output - I am not sure, this is my speculation and I remember seeing some of this somewhere - looking for feedback, not people telling me I am wrong, because I very well may be.
Old Nov 18, 2007 | 12:05 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Old Nov 18, 2007 | 02:48 PM
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
The engine in the "63" AMG cars is 6.2L V8 DOHC.
The engine in the "55" AMG cars is a 5.4L V8 SOHC.
The engine in the supercharged "55' AMG cars is a supercharged 5.4L V8 SOHC.
The engine in the "550" non-AMG cars is a 5.5L V8 DOHC.
Here are the "specs" about the 6.2L V8 engine (from the AMG press release when the engine was introduced).
Cylinder arrangement: V8
Cylinder angle: 90 degrees
Valves per cylinder: 4
Displacement: 6208 cc
Bore/stroke: 102.2/94.6 mm
Dist. between cylinders: 109 mm
Compression ratio: 11.3 : 1
Output: 375 kW/510 hp at 6800 rpm
Output per litre: 60.4 kW/82.1 hp
Max. torque: 630 Nm at 5200 rpm
Torque per litre: 101.5 Nm
Maximum engine speed: 7200 rpm
Weight (dry): 199 kg
Power-to-weight ratio: 1.88 kW/kg
Old Nov 18, 2007 | 05:23 PM
EUROTEK//AMG's Avatar
German
I always thought that was kinda weird .... AMG 55 = 5.4 L
Old Nov 18, 2007 | 05:28 PM
NickyBlack's Avatar
E63 AMG, E60 M5
it's a numbers game. buy yeah the 63 is in reality a 6.2
