What is included in a Service E+?
Old Dec 3, 2007 | 12:06 PM
GarciaE55's Avatar
e55
Hey guys,
A Service E+ is due in 2100 miles on my E55 and I was curious what this entails. Is it a glorified oil change that the stealer will try to rape me on?
Can this be done at an independent? Can we reset the message ourselves if it is a simple oil change?
Old Dec 3, 2007 | 12:35 PM
pcalver's Avatar
2007 SL550 - Aegean Blue; 2008 E63 Wagon - Iridium Silver
From a Mercedes Service site:
The maintenance services will be indicated by showing a service type ABCDEFG or H in the multifunction display (approx. one month before the maintenance service is due). Types ABCDEFG and H are classified based on the estimated time needed to perform the maintenance service, ranging from up to approximately one hour (type A) to up to approximately eight hours (type H) plus parts. Or, ~$120 to ~$960.00 labor price only.
The Maintenance System calculates and determines the service items (items 1-20) that need to be performed. Based on these service items, the system then assigns the appropriate service type (type ABCDEFG or H) which appears in the multifunction display.
So, you are estimated to need 5+ hours of labor for this service. You can probably estimate which service is required from your miles and the Maintenance booklet service listing.
Old Dec 3, 2007 | 03:47 PM
baldmike73's Avatar
I am in need of Service G. Where does that fall on the schedule. My factory warranty just ran out so the extended won't cover.
thnx
mike
Old Dec 14, 2007 | 11:13 PM
snacl500's Avatar
E55
I just got a E55 with no manuals. Could anyone help with the service "G"?
Thanks!
