Lowering A E63?
Old Dec 4, 2007 | 06:48 PM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
Lowering A E63?
I Know You Can Lower A E63 With Any Type Of Elm But Is There Another Way?
Also Does The Car Actually Handle Any Better When You Lower It And How Is The Ride After?
Any Help Would Be Great
Old Dec 4, 2007 | 07:08 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
I spoke to EuroElites about this during the GTG in Fremont.
No, it needs to be done electronically.
It might also be possible to get the suspension "recalibrated" to match the 030 specs. It is still unclear what changes are actually made.
One person attending (tigerlam?) said he had his lowered slightly (1"?) just with programming by the dealer.
The only real change in handling will be lowering of the center of gravity.
You also have the option of completely retuning the suspension by adjusting camber, caster, and toe. I have not seen anyone racing the W211 where they have taken the tuning to this extent. If they have, it is highly likely they are also using soft compound tires.
Old Dec 4, 2007 | 07:11 PM
Jrocket's Avatar
E55
Do a search using washers or links in here.
Old Dec 4, 2007 | 07:13 PM
Sean03S55's Avatar
07 SL550 / 07 E63 AMG
You can just use a set of adjustable brackets that hold the stock air ride sensors, they can be adjusted to make the car sit higher or lower. They are available from a number of dealers, I think i got mine from adjustable air ride . com.
Yes, the car does handle better once lowered.
Old Dec 4, 2007 | 08:25 PM
jangy's Avatar
2015 S212
Not just lower center of gravity, but also more and more negative camber.
Old Dec 5, 2007 | 03:34 PM
lowering
so if i lower with some of the options I can also raise the car back to stock height with the oem susp button
