Powerchip
It seems to me that the issue with the 63s is universal and has nothing to do with the tuner. Does RennTech not also have to break the seal? I just think the powerchipped cars were the first to get flagged.
Adam
I also know that PC claims to raise the speed to over 200mph. I assume they do it by raising the RPMs AND deleting the speed limiter.
As many times as I've hit it, I should know but does anyone know the revs at 155mph?
Regarding vehicles that claim to not have achieved the advertised gains, were these conclusions made by comparing post-tune dyno graphs to *expected* stock numbers or by having a base dyno before being tuned, then dynoing after the tune? If you take 5 different E55's and dyno them on the same day you will see that stock power varies greatly. Such is due to numerous factors such as the physical build quality of the engine, how the car was broken in, etc.
Pertaining to removal of the top-speed limiter, such is done totally independent to the revs. There's a numeric value that simply states the top-speed, which can be drastically extended, but not physically removed. In essence, your speed limiter is set to an unreachable MPH (ie.. 300mph) so no electronic limiting takes place - you're only limited by your car's physical capability, which is basically drag and limited power.
I think the above is something that should be accounted for and looked into.
-Aaron
Powerchip has world class service, and remember, unlike Kleemann, and Evotech, Powerchip ONLY does ECU tunes. I would imagine they know a little more than the other guys based simply on the fact that this is all they do, the ECU programming is their specialty, whereas Kleemann, and Evotech concentrate more on the bolt ons that they sell, and do an ECU program to compliment their bolt on parts.
I would bet money that my brothers Powerchipped CLS63 would beat an Evotech ECU tuned CLS63 in the 1/4 mile.
Like I said, I've seen powerchip-tuned cars gain nothing (maybe 1 or 2 hp) on the dyno. And yes, those cars had pre and post dynos. Also, they seem to lack knowledge once you try to go beyond their standard tune. For example, a member on the C32 had some custom mods and wanted a custom tune to take advantage of those mods, but they just couldn't answer many of his questions or further help him.
From my research, PowerChip has been around for quite some time (15+ Years if I remember correctly) and I felt good going with a company like that as opposed to others that started up recently. I also feel that once the chip tuners have the specs for the car, the tune is going to be pretty easy. I would bet that the tune from Renntech, Kleeman, Evotech, or PowerChip is probably VERY similar to each other. They all basically remove that margin of safety that MB puts in a stock vehicle. I do not believe Renntech can do any more that any other quality tuner can do with the same vehicle. But they can charge more because of the name.
My two cents.
The issue I have with ALL ECU tunes is that they are simply generic. Saying that Powerchip just gets them out and moves on isn't really fair. The others are no different. they all get a tune out as soon as possible and do not bother to make any changes to it unless they absolutely have to. Want an example? When MB added the dreaded injector flash. It was one of the first times that we had true data showing that the ecu maps were different on various years, since it acted differently on different model year cars. Through all of this, I have been involved with Kleeman, RennTech, EvoTech, and now Powerchip tunes. Kleeman is simply too far away. RennTech still has not been able to finish an ECU tune to satisfaction after almost a year.
That leaves Evotech and Powerchip. I like Evotech because of Oliver, but I want the car tuned on a dyno and he isn't here.
In the meantime, many of my friends in SoCal have been going to Powerchip for tunes and I had a chance to speak with them openly about all the concerns that we have (including the 63 clan). What I liked was the fact that they were willing to openly discuss and even offer to disprove some of the wives tales that may exist. I have no history with Powerchip, so maybe this is a new thing, but their customer service is great and they are very connected to the MB product line.
My two cents.
I understand that Powerchip removes the safety margin from that MB uses, but once the tune is developed, then they have to move on to different brand. They can not afford to spend years and years just on Mercedes or any one company. Kleemann and RennTech, on the other hand, stay with one brand (Mercedes), so there is an "inheret" inevitability to continue improving the ECU tune.
In either case, go with the tune that makes you happy. I'm sure some people will like a tune even though it shows no gains on the dyno (but they still feel an improvement), and others will hate a tune even though it shows 25 whp increase on the dyno. I think if you purchase Powerchip through one of the tuners on this forum, you'll have 14 days to try it out and if you don't like it, they'll give you your money back (full refund). This is a lot better than ordering through their website. And I think 14 days should be more than enough time to decide whether the tune worked or not and whether it was worth it....
MBForever:
I fully understand what you are saying, I just simply respectfully disagree. The various versions you refer to did not come about in the name of continuous improvement. They did it based on complaints and flashes.
Again, I have no history with Powerchip, I just know what is going on now. They are aware of the MB market and willing to work with me on the '06 built in '06 issue. We have also discussed potential solutions for the 63 cars. Trust me, we will do plenty of dyno runs but thats not the real deal.
How about we get a VRP/Powerchip tuned car and a RennTech tuned car to the track, where the truth shows? You ever dyno RennTech's airbox?
We will have custom tunes created for each VRP power package so there will be no generic tunes for our stuff. We are making good use of the dyno to hone these tunes.
That being said, last July, a member on this forum and his cousin came out to Famoso with 2 E55s (one was an 03 model and one was an 04 model). The 2003 model was Powerchipped (no pulley) and had an air filter, but the other car was completely stock (but had chrome rims). The powerchipped car ran a consistent 13.0 to 13.2 while stock car ran 12.8 to 13.0
Then the drivers actually switched cars and ran again, but got same results: the powerchip car ran a bit slower. The whole reason they came out to the track was because the powerchip car showed no hp gain on the dyno. And yes, he had changed the IC pump 3 weeks prior to coming to the track (and he needed that day because temp was 92 F
). Also, I've got other examples of powerchipped 63s running worse time than my stock 63, but unfortunately on different tracks.However, I've seen the Powerchip ML63 dynos and have personally driven one, and I have to say was very impressed. I don't know why the ML version of the tune is any different than the other 63 tunes, but I definately felt a good improvement when I drove the powerchipped ML (which actually showed that improvement on the dyno).
Thankfully, we have too many companies to chose from. And although I would never chose Powerchip again, I would definately consider a VRP/Powerchip versioin because I honostly do trust Vadim's and Victor's work. And I'm very thankful I've found them (as well as many other great members) on this forum, as they've helped in leading the way to better beasts
, and have guided many of us through a lot of clutter.... Last edited by MB_Forever; Dec 20, 2007 at 06:25 PM.
The satisfaction guarantee is a nice deal. I don't know of any other tuner that offers that on ANY products.
Not at all. It should hit 6500. The key is how fast will it go? If it holds at 155 - 160, then it is not tuned.
On a typical ECU tune, a few extra hundred revs is common, but I dunno what good it really does on the E55s. Our power bands start at low enough revs that we don't have to be screeming when we shift up to still be in the band. As it is, you can basically short shift it and it is almost as fast. I don't know if it is better to be in a lower gear and at 4K rpms or in a higher one at maybe 3K?
At any rate, 6500 isn't much these days. Our motors aren't exactly marvels of technology.
Veloce originally made a claim of before and after results... 40-50hp from the tune... Not a peak No# They also posted saying things like their tunes alone beating cars with other Tuners ECU upgrade + Pulley. Their ECU only cars beating cars with ECU + Pulley.
I for one jumped on them... YOU NOTICE THEY NEVER BACKED UP THEIR CLAIMS??!!!??
I just don't like B.S. And people trying to take us for fools.
Best,
RoydRage
