Issues: E55 owners please chime in(Help)
Today I floored the e55 on first and second the car pulls hard. After the top of second I pull off a bit after which I punch it one more time. This time nothing happens. The car doesnt pull at all. The RPM climbs but the car slowly pull. (Not normal at all). So I exit the freeway. Punch the gas on off the line and the cars seems fine. I enter the freeway. And it does the same thing mentioned above. First and second feels fine but after pulling off and punching it nothing happens. From 4th the tranny downshifts to 3rd but it doesnt pull at all (RPM goes up). It feels like something's not biting... Supercharger??
What could this be? Taking it in on Wednesday.
E63 P30, CL500 Sport
Definately sounds like a failing Intercooler Pump. Very common on 55k engines. Either get the pump replaced or move to the Johnson Marine CM30 pump.
Contact LET Motorsports, they just had a very good special on that pump.....
Found the thread, here you go.......
https://mbworld.org/forums/w211-amg/221657-letmotorsports-now-carrying-johnson-pumps-cm30.html
yes this could boissbly be from heat rising up (building up) the faster you go the hotter and espicaly after heavy throttel
2015 S212
First, consider wiring the pump to run at all times when the car is on. As it is, the computer is set to shut the pump down at certain times in hopes of extending pump life. The OEM pumps don't last that well, but the CM30 is rated at about 5000 hours.
Then, consider getting a larger Heat Exchanger or even better, splitting your systems (engine cooling vs SC cooling).
Good luck.
