Drag Radials vs Street Tires! video
I have run as low as 15 PSI and as high as 34 PSI in testing. I am merely sharing what has worked for me in the last hundred passes or so.
FWIW, there must be some sort of buried torque management software that limits power when both gas and brake are applied. Without removing that and possibly adding a converter, there is no point in leaving higher. (especially in a car than makes 90% of its torque just off-idle)
i also agree that we're limited by tq management because d/r's only give me consistency. my best 60' times are nearly identical on 16" d/r's compared to 19" street tires but they're much more repeatable on the d/r's.
http://www.tirerack.com/tires/tires....+Drag+Radial+2
"It is also important to remember that the Drag Radial operates most efficiently on the strip at cold inflation pressures of between 15psi and 20psi (in no case should below 12psi be used)."
