Need advice
Old Jan 8, 2008 | 05:28 PM
Ckim1021's Avatar
2007 E63
Need advice
Hi guys.
I had oil leak about two months ago and SA told me that it was from transmission. SA said that the bad gasket was replaced however I noticed more oil drops on floor.
Last weekend, Check engine light came on so I took it to dealer. Today I got a call from SA and told me that they have not found the cause of the leak. They had to take out the transmission.
Should I be concerned?
Someone told me that leak problem is not easy fix and the car will have leak problem all the time.
Old Jan 8, 2008 | 05:31 PM
Vadim @ FD's Avatar
S600TT, R350
No true. What dealer are you at?
Old Jan 8, 2008 | 05:43 PM
Ckim1021's Avatar
2007 E63
It is at House of import.
I am just worried because I always had bad luck with car.
My previous car, Cayenne turbo had so many problems.
So do you think that it will be oaky once they find the source of the leak?
Old Jan 10, 2008 | 01:51 PM
Ckim1021's Avatar
2007 E63
My car is still at the dealer. It has been almost a week!
The cause of leak was bad engine oil pan gasket.
The cause of Check engine light is still not known however SA told me there is DTB for 63 engines. I believe that they replaced intake manifold gasket.
SA is hoping that this would take care of Check engine light.
Hopefully there won't be anymore problems.
Old Jan 10, 2008 | 03:39 PM
tthoang1's Avatar
2004 E55 AMG, 2002 Porsche 996 TT, 2004 BMW x5 4.8is, 2004 F360
I would keep a careful record of all the problems, dates, repairs, etc. I don't know if you purchased it new. If you did, and the problems persist, the option of lemon law is open to you.
Old Jan 10, 2008 | 03:56 PM
Ckim1021's Avatar
2007 E63
Thank you. I am keeping all the records so if it happens again, I can do something about it.
