Worlds Fastest 1/4 mile MBZ
Old 04-19-2009, 09:12 PM
  #226
blackbenzz's Avatar
haters crazy
Originally Posted by AMGSC
Vadim still insists that an 8 rib pulley is not necessary. I will most likley keep my 60mm SC pulley and enlarge the crank pulley to 132mm to get to 17psi. With the rebuilt/reinforced engine and tranny, I should be able to max out the Autorotor 2.2 to 26psi but I doubt that can happen with the M113 motor where the redline is so low. That's why the titanium rods were never installed.
That will be awesome buddy. So only thing you did to the bottom end is pistons? Do they have a special coat to work with our blocks? No rods or sleeves? I am interested to see how your car turns out. One day I will probably build my motor and turn up the boost too, I just don't know which route I'm gonna go. With a built bottom end I see the old Kleemann blower being able to put out 600+whp and that a conservative estimate
Old 04-20-2009, 09:36 AM
  #227
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Originally Posted by hooleyboy
I would be #62 on the list for 1/4 time and #2 for 60ft time.
The only problem is that the list only shows the best 60' on the best runs. I know that there are some better 60' times that just didn't happen on their best runs.
Tom
Old 04-20-2009, 09:43 AM
  #228
jmf003's Avatar
'03 SL55
Tom
Sounds like we need a best 60' list on AD!
Old 04-20-2009, 09:55 AM
  #229
kchristos's Avatar
Don't have a Mercedes right now...
Originally Posted by juicee63
Check out the 1996 E300 Turbo Diesel !!!! WOW
11.468 121.010 7.414 96.620 1.767 Mercedes-Benz E300 turbodiesel 1996 Antti
Can you imagine getting whopped by a 1996 E300, thats hot
This car must have some serious mods right? Usually the diesels from that era are slow like dogs. I am curious what kind of mods can be done on a diesel ?
Old 04-20-2009, 10:00 AM
  #230
jmf003's Avatar
'03 SL55
Boost. Lots of turbo boost. The Dragtimes entry says 38 PSI, http://www.dragtimes.com/Mercedes-Be...slip-6881.html
Old 04-20-2009, 10:01 AM
  #231
TMC M5's Avatar
Lol...great...I got volunteered for another project...you are worse than my ex-wife..
Tom
Old 04-20-2009, 11:43 AM
  #232
blackbenzz's Avatar
haters crazy
Tom
Yup, 1.52
Old 04-20-2009, 11:47 AM
  #233
V12Godspeed's Avatar
Your worst nightmare...
I wonder what will it take to get a 1.4x....
Old 04-20-2009, 12:00 PM
  #234
JAYCL600's Avatar
new balance
shed an impossible 1000lbs from your car and u will get there
Old 04-20-2009, 12:04 PM
  #235
TMC M5's Avatar
It is not impossible. The trade off is that the car would cease to be a luxury car. I am not sure anyone has the real desire to have a stripped out CL65/600. It kind of takes away from the whole purpose of the car..
Tom
Old 04-20-2009, 12:21 PM
  #236
Wow...I thought maybe 500 lbs, it's just not going to happen unless we have a boat load of power.
Old 04-20-2009, 12:27 PM
  #237
jmf003's Avatar
'03 SL55
Tom
Every now and then I check out RacingJunk.com just to see what's for sale. Here's an R129 SL for sale that could probably run a 1.4 or better 60' time but to Tom's point any semblance of luxury is long gone: http://www.racingjunk.com/category/2...-Mercedes.html
Old 04-20-2009, 12:31 PM
  #238
blackbenzz's Avatar
haters crazy
A reinforced driveline. The 1.52 I ran was only a 2000rpm launch. If i get axles made you will probably see a 1.4x out of a benz if nothing else breaks
Old 04-20-2009, 12:48 PM
  #239
phoung's Avatar
'03 clk 500. WTB slk55
what about that guy that put a SLR engine into the slk. its on youtube. it destroyed a enzo
Old 04-20-2009, 01:04 PM
  #240
Nothing like pretty in pink. That thing will eat the quarter I wonder in how much...would sure be nice to see a video of it.
Old 04-20-2009, 01:36 PM
  #241
TMC M5's Avatar
Nice find!
The 1,000lbs weight loss is certainly do-able. Here are some weight loss ideas which I wouldn't do:
Take out all the double paned glass (front windshield and rear window included) and replace them with lexan. (Estimated savings 75+lbs)
Take out all the ABC suspension pieces and replace with a conventional coil over suspension (warning some assembly and welding may be required ). (savings 175lbs)
Strip out massage seats and rear seat and replace with carbon fiber race seats up front, also need seatbelt harness as factory seats have the belts attached. (150lbs)
Replace factory hood with carbon fiber hood with no sound deadening material...(might as well have louvers, ducts or scoops built into the hood to allow more under-hood air volume). What the Heck...might as well replace all metal body panels wth carbon fiber pieces while we are at it. (50lbs)
DYMAG wheels. (60lbs)
Replace big brakes (at least on CL65) with a small brake kit or throw some carbon ceramics rotors on. (40lbs)
Take out all carpeting and leather in the interior and trunk. (50lbs)
Tear out sound deadening materials in doors, behind dash, and roof. (75lbs)
Take out motors for windows, sun roof and trunk closer (Jay doesn't need to do that delete ) (25lbs)
Take out windshield washer reservoir (15lbs)
Custom lightweight titanium exhaust with Cats deleted. (50+lbs)
Lightweight battery replacement (20lbs)
I think if you dump all other "non-essentials" you could probably stand to lose another 200+lbs (power steering pump, A/C compressor, etc..)
Tom
Old 04-20-2009, 01:59 PM
  #242
^^ Loose all that and you will definitely be traveling in a rattle box, not a luxo car...
Old 04-21-2009, 12:30 AM
  #243
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
No rods since the stockers are already forged but they were polished and you can see the pics on my other thread. Block was special coated as you said so it will be extremely strong. That's why it took so long to get this thing done. I'll stop at 17-20psi even though our 2.2 Autorotors are efficient up to 26psi.
btw... How is the fit and finish on your CF hood? Is it from VIS? Where can I get your battery? Again what's the brand if you don't mind me asking?
Old 04-21-2009, 12:35 AM
  #244
juicee63's Avatar
2007 CLS63 030
YOU GUYS ARE DONE!
Old 04-21-2009, 01:19 AM
  #245
Former Vendor of MBWorld
hooleyboy's Avatar
C55,SL55,C63
That thing has to be hell on wheels. Just the kind of thing i like.
Old 10-24-2009, 09:05 PM
  #246
blackbenzz's Avatar
haters crazy
Where is the most updated list? I wanna see how fast I need to go
Old 10-24-2009, 09:15 PM
  #247
juicee63's Avatar
2007 CLS63 030
Alans 131 mph trap
my 1.47 60ft
You hold the ET record non nos???already correct.
The fastest passes since belong to Alan in his E55, also the quickest which you already own.
If you need a comprehensive list maybe Tom can help by updating the most accurate list which is on Absolutelydriven..
Old 10-24-2009, 09:19 PM
  #248
blackbenzz's Avatar
haters crazy
Alans 131 mph trap
my 1.47 60ft
Thanks Josh. I'm guessing Stephen still holds the overall quickest and fastest time for benzes? I'm shooting for the quickest title, even if it lasts just 1 day. I will be practicing tomorrow and then going for the record friday
Old 10-24-2009, 09:21 PM
  #249
juicee63's Avatar
2007 CLS63 030
Yeah its 10.58 on thy bottle breaking rear ends , hehe
DAM MAN GOOD LUCK , I for one would LOVE TO SEE YOU set the bar a bit higher
http://www.dragtimes.com/Mercedes-Be...lip-11883.html
Old 10-24-2009, 09:34 PM
  #250
Stephen04E55's Avatar
'09 CLK550, '21 Camaro ZL1 1LE, '06 C55 AMG, '20 AMG GT53
Go for it! With those awesome 60' times without any boost issues, my 10.58 is easily beaten. That will give me some motivation to go faster. I can't believe that 10.58 has stood for 18 months.
Quick Reply: Worlds Fastest 1/4 mile MBZ
