DYNO...696 HP 55 motor !!!
1 Post
STS,FGT,12C,P85D,M4
well, that car isn't making 696HP either..... anyone can generate a graph and post it up..... they don't post real #'s for a reason....
Man you funny...Look at reality...I havent seen VRP car making 696 HP yet...No disrespect to VRP or anything I sure with time we will see Havoc 1000 HP kit...BUT I see these Kleemann dyno that is looking very healthy rightnow...and so far only Kleemann and Evotech where able to come close to 700 HP with thier cars....They have reliable and proven kits and dont want to risk their reputation...Its for normal people not for crazy HP heads like US...Who is willling to take that risk...Go beyond, willing to experiment...and sometimes use our cars for R&D...not knowning the final results yet...or even if the kits is working or reliable at the end...
Finish you car tuning 1st... then We talk about it...if you get at least 696 HP![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I really need to step in here and add my 2cents. I am gonna call it the way i see it. I dont mean to offend anyone. I have not posted much on this board, but have been reading and following quite a while since I bought my CLS55 a while back.
First, the Kleemann dyno chart looks like ***. I would never trust a tuner that is advertising a dyno sheet that shows AFRs in the 9s. What are they trying to prove, that they have no clue on what a properly tuned car should run at? Also, crank hp is bs. Show me a dynojet/mustang dyno and then i will believe it. But i can tell you that if its making even ~550whp with that tune, you can probably pick up another 30-40whp if you bring the AFRs to 11.5-11.7 range.
Second, although i applaud VRP for taking on new challenges, i have seen way too many threads where a new project is announced when other things are still left without being perfected. I would rather VRP perfect one mod and build form there.
I like the "VRP550" thread. They approached a single mod, and tried to fix the ECU problems of retarding timing, and dumping fuel. It really really surprises me that VRP has done heads without flow testing before and after INCLUDING port velocity. No offense, but if my shop gave me head without it, i would consider the head not done. As many of you guys have seen, just because it feels faster does not mean diddly.
I am hearing statements such as "...VRP cams should be just drop in and no retune needed..." The VRP cams sure look nice, but do we have any specs? I hope i dont hear that they are "secret." In other parts of the tuning world, cam specs are readily available. You and your tuner should now what your duration, lift, lobe profile looks like. All these will change how your car even idles and drives around town. Not everything is about WOT.
I have yet to see a proper dyno of the before and after cams or heads to show an improvement on the V8 compressor engine. Not that its not possible, but i have not seen it on this forum. Jackpro1 is the only member that has done a VRP head and cams and he has lost power. His AFRs look pig rich. I am not sure what the timing are. But now VRP wants him to ship the car to him which will cost $2200 so they can tune it.
Should this not have been thought of or discussed before he embarked on this expensive project? What happens if he sends his car and spends the money and his car is not making significantly more power than a car with just a pulley? Even in VRP550 thread, just with a pulley and tune costing $2500, they are putting down ~470whp. Do you guys think that dropping another ~$10k including labor should allow jackpro1 to make at least ~500-520whp?
If not, and he was shared this information, maybe he would not have gone this route. I dont mean to go off on VRP. Again, i applaud their projects. But we can not allow other members cars to be used for R&D and let them foot the bill if it does not work out.
At the begining of the vrp cam thread there are before an after dyno's of my car. Heck Ive probably posted more dyno runs than any body else on this site. Sorry to lazy to paste the link.
The reason the afr's are of the charts has to do with dme correction, a stock e55 is pig rich on-top to control egt's. These cars are tuned from factory with long top end passes in mind ie autobahn. Before you make changes to fuel map you must first change a few of the correction tables or you will be going in circles.
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
You're 2 Cents is Greatly Appreciated and I Totally Understand Where You're Coming From.
For I Can Only Speak For Myself and Perhaps My Issue is Not Only Wanting the VRP Stage 3 Heads, but Wanting It Now!
These Race Ported Head Modifications Are Just Coming Out For the 55 Kompressor and No One Really Knows The True Exact Numbers. But Come On Man, I'm Footing The Build and I'm Not Even Worried About It. An Internal Combustion Engine is Not Rocket Science! It's Just A Big Air Pump, For God Sake. It's No Secret What Makes an Internal Combustion Engine Have More Horsepower. No Worries There!
In Regards to VRPs Heads Not Being CNC Ported and that Every Head will Be Different. Remember, We Went to VRP, VRP Didn't Come to Us. This Is the Beginning and Only a Few of Us Want To Do This Mod. I'm OK With It and that's All that Matters. But I understand Why you're Not.
CLS55, BMW 540, SUPRA
I also notice that "smoothing is set to 0" which over exaggerates numbers. If anyone has actually worked on a dyno, i can drag the smoothing from 0 to 5 on a run and change things by 50whp. As long as all runs are on the same smoothing level its ok, but it just exaggerates the numbers compared to if the smoothing was 5 where it should be.
![](http://69.17.158.20/vrus/e55/dynocams.jpg)
06 EuroElites E55
![Popcorn](https://mbworld.org/forums/images/smilies/popc1.gif)
The only dyno i have seen with before and after cams is a dyno where before cam showed i think 514whp and after showed 537whp. The problem is that the 514 number showed a 0.96 SAE correction and the 537whp run showed a 1.01 SAE correction. That means that at 1.00 SAE it would actually be reading ~535whp. Remember a 4% undercorrection at ~514whp is 20whp. And the 537# at 1.00 SAE correctionwould actually be 536whp
Does that sound like an improvement to you?
Yes internal combustion engines all work the same way. But trust me, if it was that easy we would all be making a 1000whp
Let me give you an example. Lets say that the following is the flow sheet from a head. This is just pure example. The customer is told, "...wow your head flows 180CFM." Customer is all happy that he has a nice flowing head. Here is the problem. It makes me laugh, cause the customer is never going to see 180CFM. Do you know why? Cause if his cam has a lift of 9.3mm (~3.66") he is only going to see 160CFM. Who cares what the head is flowing at 0.5" lift if you are never going to get there.
Whats missing from the following is the PORT VELOCITY. I see one out of 100 head jobs where the porter actually tests for this. So you might have picked up some CFMs at the higher lifts and a little bit down low, but if you lost 20% port velocity at 0.1"-0.35" then your car will drive like a dog. We do this to drag cars specifically, cause we dont care about 0.1"-0.4" of lift. The car will leave the line at 6000rpm and never drops below that. So we dont care if port velocity drops in the lower ranges. But in a street car, its a definite story.
LIFT FLOW
0.1" 100CFM
0.15" 120CFM
0.20" 130CFM
0,25" 140CFM
0.30" 150CFM
0.35" 160CFM
0,40" 175CFM
0,45" 180CFM
0,50" 185CFM
The only reason i am going thru this nauseating detail is that i want you guys to get a better understand and not just accept everything that is fed to you.
#32
You will usually get more gains with less known and less branded tuners. That is because companies like Kleeman and Renntech come out with upgrades that took money to develop and when they are finished with their product, they sell it as nice conservative packages that will give your car a very nice respectable bump in power but will also retain stock drivability and reliability...as well as put a nice chunk of profit in the tuner's pocket.
A company like VRP isn't a tuner who claims to give you a warranty and give you "comfort power" like Kleeman. They are more aggressive and are willing to push the limits. Of course you will gain more power with a company like VRP since that is their focus. Some people are more comfortable spending the same or even more money on a less powerful mod but having the peace of mind that everything will be fine than knowing that they have another 50hp over the next guy. Me personally, I go for power and ingenuity. Being a guinea pig is very risky...but there are a few complete nuts out there who want the best in their class...and those are the people who will invest extra money and put much more on the line to have these slightly experimental mods put into their cars.
I always thought the biggest package Kleeman had was the 640hp package? Maybe this didn't include Camshafts and Intercoolers? Is that was gives it the extra 60hp? I could definitely see those two mods giving at least an extra 60 hp.
I believe that if you want more than 650+-hp on a 55K car, your best bet is nitrous oxide. Proven, simple, effective
#34
Yup, its all marketing. They will post higher dyno numbers than their competitors. There will be a few guys out there with more money than knowledge who will buy into this and go for the Kleeman package since it looks so much more powerful.
#35
With all do respect i dont think you read any of the posts i made in this thread in detail. I just posted the dyno sheet posted by VRP and there is no difference in the power between the before and after cam. Also, the one person that has done cams/head has not increased power. So based on what are you saying that VRP makes more power?
#36
The problem is that just because someone is grinding a nice shiny hole and making the ports bigger does not mean that its actually going to perform better.
But hey, I'll be the First to Admit that I don't Know it All!
Honestly, I never thought I would ever own a Benz, much less an SL55 AMG. I rather pay someone to do surgery on this badboy, then do it myself though. Don't worry brother, we'll get it right.
#38
You're correct, the K4 Kit is rated at 640hp.
The only difference is the addition of Intercoolers at ~60hp?
#39
S600TT, R350
Saman:
Thank you for pitching in. Looking at your posts, I can only conclude that you have had a lot of experience in tuning and your contributions are welcome.
Up until very recently, I have been on this board since 2002 - under vadim@evosport - most AMG customer were mostly interested in before and after. Very few had the knowldege and understanding of how engine works and operates. As the time has progressed and Kompressors started to reach second hand market, client base has shifted to more hands on crowd.
From 2002-2005 I was part owner at evosport and developed their Kompressor line. You can search it under my previous handle. At that time very few wanted to go further than bolt-ons, as warranty concerns were allways on their mind. Now, the game has changed, clients are willing to dig into the engine and push it to the limit.
Victor and I just got together as a team last December, a lot of components - cams, heads and so on were sourced by Victor from the vendors. My job now is to put all of them together and make them work as a package.
This is what we are working on right now. Our goal is to create a proven and affordable stairway to power for Kompressor owners. And we are in the process of building it.
So feel free to offer your thoughts - in the end it is all for benefit of this community.
#40
I like the "VRP550" thread. They approached a single mod, and tried to fix the ECU problems of retarding timing, and dumping fuel. It really really surprises me that VRP has done heads without flow testing before and after INCLUDING port velocity on every single head. The heads are not CNC ported, so every one is going to be different. The excuse of quick turn around does not go well with me cause no owner would have a problem of waiting another day or two to make sure they are getting the product they were promised. No offense, but if my shop gave me a head without it, i would consider the head not done. As many of you guys have seen, just because it feels faster does not mean diddly.
I am hearing statements such as "...VRP cams should be just a drop in and no retune is needed..." The VRP cams sure look nice, but do we have any specs? I hope i dont hear that they are "secret." In other parts of the tuning world, cam specs are readily available. You and your tuner should now what your duration, lift, lobe profile looks like. All these will change how your car even idles and drives around town. Not everything is about WOT. Assuming that the cams offer higher duration and lift, a tune is a must!
I have yet to see a proper dyno of the before and after cams or heads to show an improvement on the V8 compressor engine. Not that its not possible, but i have not seen it on this forum. Jackpro1 is the only member that has done a VRP head and cams and he has lost power. His AFRs look pig rich. I am not sure what are the timings . But now VRP wants him to ship the car to him which will cost $2200 so they can tune it. And there is no guaranty yet.
Should this not have been thought of or discussed before he embarked on this expensive project? What happens if he sends his car and spends the money and his car is not making significantly more power than a car with just a pulley and tune? Even in the VRP550 thread, just with a pulley and tune costing $2500, they are putting down ~470whp. Do you guys think that dropping another ~$10k including labor should allow jackpro1 to make at least ~500-520whp?
If not, and he was shared this information, maybe he would not have gone this route. I dont mean to go off on VRP. Again, i applaud their projects. But we can not allow other members cars to be used for R&D and let them foot the bill if it does not work out. I would love to see VRP attack jackpro1's car and let us all see what kind of power it puts down before they even take a single $ from another member that is thinking of doing a head or cam. If that is not fair, then i am not sure what to say.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
#41
Saman:
I appreciate the welcome and your explanation. I honestly applaud your efforts in this market. My only advice is to say that R&D is everything. Also, i would honestly hold off on selling more complex packages until you guys have the ECU tune down perfect. I think the pulley and tune VR550 thread is great. It seems like that combination you guys have gotten straight.
I think you guys should do a head and cam setup locally get the tune down perfect and pass it on to customers like jackpro1 whos tune does not look right and seems to be down on power. I will be much more active on this thread since and not to step on any toes but if you ever want an opinion or input from another angle i would have no problem throwing my 2cents. Hell, if things turn out good, i might throw my CLS55 in the mix
#43
Does that sound like an improvement to you? This is the dyno i am talking about![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![](http://img168.imageshack.us/img168/898/dynosmothing5zy9.png)
Here are all the same dynos uncorrected, the car made the same power despite 17 degree difference in air temp and lower barometric pressure, you do understand that correct.
![](http://img297.imageshack.us/img297/386/dynouncorrectedsmt5gs4.png)
More food for thought the car ran 11.34- 123.80 in 71 deg weather in Florida before the cams, slip is on dragtimes. Then ran 11.38 at 123.80 in 90 deg weather at MIR and was the highest trapping e55 there. I'm sure my fellow board members who were there can verify the et data and chyme in. By the way I had slr copies before the vrp cams that only made 7 rwhp over stock.
These are the facts, but by all means please show me a dyno with a 50 rwhp difference from moving the smoothing. Do we continue to discuss this civilly despite your assumption being way off.
#44
2003 E55 AMG
Saman,
I am always open to input and feedback.. I can take constructive criticism.. Its the only way someone can build and improve. Also, I dont claim to be an expert.. I just go out and look for all the experts and get them to build things that I want. My goal is to provide quality parts at the best possible prices I can.
Regarding the VRP cams..
I dont publish the specs, because, unlike the domestic and JDM markets, parts and services are very expensive. Euro tuners dont want their stuff copied so that is why alot of the information is secretive.. this was the main driving factor behind me doing my own research and coming up with my own products (rewind 2yrs back). I refused to pay $4K for a TB kit, $4400 for headers, $4K for a CF airbox, $4K for pulley + ECU.. Are you seeing a pattern yet? If you look at the market space now, you'll see alot of market correction in the pricing structures.. Take a guess why that is.
Have you seen Kleemann or Renntech publish their cam specs? If I didnt tell you so, you might not know that Kleemann cams are nothing more than Schrick cams which will maybe get you 8rwhp.
Renntech cams = Evotech cams.. Evotech made and supplied them for Renntech while they were still together. We had a set of those cams also and on the car we installed them on they were also 7rwhp increase. Most likely the Evotech cams = Schrick cams because the power output was identical.
Now, enter our cams: more lift, more overlap, and change in LSA.. RFlow's BEFORE dyno was done in 74F weather (Jan I believe) with a correction factor of 0.96. The AFTER dyno was done in 92F weather (Aug) and correction factor was 1.01. They picked up 30rwhp and shifted the torque curve 40rwtq @ 4,000RPM.. Look at the area under the curve and not just the peak numbers. There was NO ECU retuning done.
Another member (BMS - 2005 SL55) also installed a set on his K2 car.. He picked up 25 or 30rwhp.. I cant remember, but the car was dyno'd by Sunil. Again, no ECU changes were made.
Rocket is having some issues with his car right now, but we dont know if it is timing, fuel, or what. I called them drop in replacements because on the first 2 cars we did, we didnt need to change the tune and the cams made good power. I figured if we actually tweaked the tune, there would be even more power to be had.
Regarding JakPro and the Heads & Cams.
Jim and I have talked on and off pretty much for the past 2 yrs. He has always been supportive and enthusiastic about all these projects.. When we discussed the heads & cams intiative, since my car had not been back together, I mentioned to him that I couldnt provide any solid gaurantees but I was confident enough that I invested $18K in my own set of heads for my car (which have been done for a while and are awaiting their new 5.7L motor).
Based on some information I recieved from 2 reliable sources, I was told just doing exhaust port opening would yield 40hp increase on these heads.. Our stock E55 exhaust ports flow about as much as a 1990's 5L Mustang head... Its that bad. Based on this information I gave a conservative estimate that a good set of ported heads with our cams should make 70hp - 80hp.
Jim and I had talked many times about the possibility of boost loss, or how the car would run with the stock tune after all was said and done. In the end, I said that worst comes to worse we could custom tune it if we found that the Kleemann program he had didnt support the new mods. He is pioneering the VRP heads & cams just like he pioneered the SLR cams in his car.
After the car went back together and he drove it, he noticed the car was ALOT faster and he could spin the tires at will which he could never do before.. At his altitude the car just was sluggish. He told me that it was such a DRASTIC change in power and was so excited. Heck.. his Master Tech @ MB who drives hundreds of cars (including modified Kleemann V12TT cars) said Jim's car was the fastest car he has even driven; hands down.
On the datalogging that he did, there was no boost drop which told us that the port velocity and the combustion chamber size were just fine.. I have had the heads flowed for myself, but with Jim's pair and wanting to get the heads back as soon as possible, we skipped that step.
We both know that with some tuning that car will be a monster.
Please dont think for a minute that Jim or anyone else was mislead or promised something that wasnt true.
Again... I do appreciate the input, and everything I do, I've always thrown out there to be criticized and poked at.
In the end, we will have tried and tested packages that will be turnkey and reliable.
#45
Rock dyno first with your current tune and see where you stand. You will see the difference, I have said all along what my position was in regards to porting the heads on an e55 little or no gains imho.
#46
That's why there is a correction factor and the weather conditions are clearly posted
. Look at the difference in weather and you will see your power increase. The smoothing is set to zero on all the runs posted but what smoothing would you like to see. Here is the smoothing on five the delta is the same, I would like to see a 50 hp difference on smoothing.
Here are all the same dynos uncorrected, the car made the same power despite 17 degree difference in air temp and lower barometric pressure, you do understand that correct.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
That is why i said in my post that since all the runs have smoothing set to 0 that its ok for comparison purposes. But you see that just changing the smoothing to 5 in fact did change the baseline numbers. Also, 17degrees of ambient temperature do not change power output by 20whp. Your car does not see ambient temperatures. Its your IATs that determine that. Why dont you look at intake air temperatures when the ambient temp is 90F vs 70F. The IATs will be different by just a few degrees. And that wont make a 20whp difference.
As far as the 50whp difference comment on smoothing. I said i can change the numbers by 50whp on a run. I was not talking about your particular run. On a high horsepower car it holds true. And you can see that the uncorrected runs show absolutely no difference in power.
#47
2003 E55 AMG
This is one thing that will get pounded into your head over and over..
Our cars are not like anything you are used to modifying.. they are the most sensitive to IAT I have ever seen. There is a HUGE difference in power between 74 and 92F. Trust me. The IAT-to-timing maps on these cars are like downhill ski slopes; power drops dramatically.. If you cant maintain < 140F IAT you are already losing power.
Because our stock intercooler circuits are very poor (location and capacity) stationary dyno pulls are affected greatly by the ambient temps in the dyno room.
You will start to learn all of this first hand once you start tinkering with your CLS.
#48
I guess we should stop using sae corrections, If you look at my post I always post both uncorrected, sae and sometimes even std for comparison. The reason for corrections are obvious and especially holds true in this case because its the same dyno, same car, and is used to rule out the weather. Once again look at the delta no matter what the smoothing is
You obviously have never dynoed your 55 in different weather and don't understand how much your Iat's are linked to ambient air in an e55. You seem to forget that blower output speed is constant with a given pulley so hp will vary greatly with air temp and density. Take your cls55 to the track during different times of the year to verify for yourself.
#50
I'm Not Funny, Just Insane! ![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
I am Looking at Reality, Both Kleeman and RENNteah would Not Do the Head Work I wanted or My Complete Build for that Matter.
Hey, it’s My Benefit Because I’m the Paying Customer and They’re Not Getting My Cash. These Big Named Tuners Are Stuck On Themselves. I Understand I must Pay To Play, But Don’t Take Advantage of Me With Over Priced Small Modifications and Feed Me Some Bullsh*t With Guaranteed Performance Numbers and Not Even Want to Touch The Heads and Go For Some Serious Horsepower.
As far as I’m concerned, They Can Take Their Little Kits and Shove It Up Their Exhaust!
You Got it!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
You Got it!
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
