RT ELM - before and after
08 E63
S600TT, R350
Compared to the old unit, it is easier to install and easier to remove with out leaving a trace.
It works on all Airmatic and ABC cars.
You can not drive on "Low Rider" setting, but for the car show it will look good.
2015 S212
Lowering the car does add stress to the suspension and especially the airmatic. You basically are under load all the time and have little modulation. But, such is life!!
If that is the lowest setting on the module, I have to agree that it is not very dumped. Mine dumps. RennTech says not to drive with the car on any level lower than 3. Many do anyway.
Damn Vadim, I wish I would have known. I would have been happy to hook it up with some extended knobs.
2006 E55
Vadim, did you notice that one of the wires in the instruction manual was labeled incorrectly? Luckily I took my time and even did the omega test (I forget what its called) and found out the color they specified didnt match up
2006 E55
S600TT, R350
2006 E55
2006 E55
the blue one was for "b22/9 right front". At least on mine (4 wire).
anyway, if anyone installs it themselves, make sure you check continuity (I found the right word
) and take your time
