E63 tranmission is acting weird when cold?
Old Feb 26, 2008 | 06:34 PM
hkpooh's Avatar
is under sport mode and whenever cold start it will feels like it is slipping when it shift from 2nd to 3rd.
For example, you drive off from the garage in the morning, you just give little gas to get your car going.....everythign is fine until it shift from 2nd -3rd gear, the RPM will jumps and you can hear it and feel it just... like giving gas without engaging the clutch on a maunal car.
Is it slipping? anyone have this problem?
and the brake squeaking is killing me, anyone have the TSB for changing the brake pads?
Old Feb 27, 2008 | 04:02 AM
scrwmpwr's Avatar
c55
maybe part of the warm up process, shifting @ higher rpm warms the fluids faster.
or the trans fluid level is low
or the 2-3 upshift needs adaptation
Old Feb 27, 2008 | 09:22 AM
FCSmthree's Avatar
95 C36
Same sort of thing happened to my 55 after not starting it for 2+ months, however it seemed from when I shifted to drive and accelerated a bit it was slipping, after it warmed up it was ok and it hasn't happened since.
Old Feb 27, 2008 | 11:08 AM
juicee63's Avatar
2011 twin turboed prius
rear axel brake squeal TSB : DTB - P-B-42.10/76
front and rear axel brake squeal TSB : DTB - P-B-42.10/79
There is a new update for the TCU, get your car a Service appt.
Good luck,
Old Feb 28, 2008 | 12:55 AM
adx's Avatar
adx
Happened to the CLS55 and had the valve body changed. According to my service rep, it seems to be a common occurence with the E and CLS models for years 2006 and up.
Old Feb 28, 2008 | 02:31 PM
hkpooh's Avatar
Good luck,
update...
just got my car back yesterday night and on paper it says engine and transmission software updated. problem fix.
this morning I try it, the symptom still there but at a very minimal level.
also, it seems like it fixed the sluggish or power lose on some situation.
The transmission seems response or shifting a bit more agressive than before the update, not sure if it is becasue they reset it?
