Water-Wetter?
Old Mar 9, 2008 | 08:45 AM
NGS_E55's Avatar
2013 CLS63 2004 S55
Water-Wetter?
Are you running it?
In radiator/other?
Old Mar 9, 2008 | 09:33 AM
LOVEMYBS's Avatar
10 Cayenne GTS, 07 Porsche 911 Turbo
Yes, in all my cars. I have previously seen a temperature reduction of 10-15 degrees especially in hot weather.
Old Mar 9, 2008 | 02:51 PM
jpohl402's Avatar
E55 then E63, now back to an E55
More info please? What exactly is it.........
Old Mar 9, 2008 | 03:17 PM
NGS_E55's Avatar
2013 CLS63 2004 S55
I also think I heard people running it in IC pump resovoir? is that correct?
Water-wetter is a redline chemical additive that reduces friction/boiling points to lower temperatures(from what I understand).
Old Mar 9, 2008 | 04:22 PM
regor60's Avatar
06 E55 Black
Arrow
Ic reservoir = radiator reservoir
Old Mar 9, 2008 | 04:32 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
unless you've separated your cooling and i/c circuits.
i do run surfactants in both my radiator and i/c circuits. in the radiator to help with cooling and in the i/c reservoir for lubrication purposes so that i can avoid using a glycol based coolant which decreases cooling properties.
btw, i've found that royal purple's version causes less foaming compared to waterwetter.
