NEED HELP!! Parktronic Acting up!!!
Mercedes
So i just got done installing my new hid kit for my fog lights and i took the car for a test drive. When i put it into drive the parktronic sensors just went to the 4 inside red lights....i read that this is the system error message for the unit....i cant figure it out and i use it everyday!!!....
Did you take the bumper off?
My guess is that either the main connector (located on the drivers side of the bumper in the foglight area or one of the sensors got unplugged or is partially unplugged. If this is the case and you restore the connection, it will work fine and clear the fault indicator (red dots).
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
If they are plugged in correctly, then you may have to move your ballasts,
they emit some RF and can interfere with electronics that are in close proximity. Did you try it with the fogs off?
