My 06 E55 feels slow now, what benz is faster/quicker?
how do you think an E55 would do against that S65 performance wise and as a Daily driver?
) with some R1 compound tires. I say go 65 hustler. You get bored with that, have the ECU/TCU flashed for over 700hp. You get bored with that, it's 1000hp Supra/Viper time.
S600 vs E55 is closer but modded vs modded the V12 takes it.
Top 1/4 times for both of them fully modded with nitrous are almost identical - high 10's.
S600 much more of luxury feel so I am not sure it would give you what you're looking for...you may have maxed-out the MB line my friend!
Would probably need to spend $20K anyways to get the E55 to the high 10's...may need to look into Porsche Turbo as alternate, as a first guess. If 4 dr sport sedan is criteria, may need to wait for the Caddy
Handling wise however the S600 is really nimble... much of it down to the ABC Active Body Control which really does make the car feel like it is on rails... Putting on 19" wheels helps also... You are aware of the weight of the TT V12 up front... but kick down... feel the twin turbo's kick in... 612 torque at only 1500 rpm... and all else fades into inconsequentiality
It is nothing short of phenomenal... A "civilized" E55..
Chris
Just logging on to give you all a little heads up... it's all
someone is yanking your chain...
god bless em'..
http://www.dodgecharger.com/forum/in...html#msg457598
http://www.cuda-challenger.com/cc/in...opic=43387.165
http://www.dfwstangs.net/forums/show...3&page=6&pp=50
and if you follow the links you will find many other similar posts...
anyhow,.. you should be made aware... so he doesn't waste your time as he did ours...
strat (aka brock samson) out...
god bless em'..
Troll in the hole!!!!!
Thanks for the heads up.
