supercharger belt slippage??
04 E55, 12 GL 450(wife)
How would I know if my supercharger belt is slipping? I have never had it replaced and the car has 26K on the odometer. I asked the dealership how much to have it replaced and they told me $175. I wanted to be sure that it was actually slipping and would need replaced before I had it done.
Yuille36 (05-01-2021)
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
I think you would notice a power loss and motor noise.
26K you should be fine to 40 at least..
It's also a real easy do-it-yourself job. Less than 10 minutes.
All you need is the belt ($30 +/- from a decent auto parts store) and a 17mm box end wrench.
Just remove the belt cover, fit the box end wrench over the tensioner socket, rotate it counter-clockwise, slip off the old belt, slip on the new belt, allow the tensioner to re-engage, remove the wrench, replace the cover.
2003 E55 & 2014 GL550
That is out and out rape. Just cannot believe what some of these dealers charge. I am serious, this is literally THEE easiest thing to change on the car. A 17mm socket wrench and 60 seconds is all it takes. 30 secs if you've done it before.
![action](https://mbworld.org/forums/images/smilies/action1.gif)
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Jim,
I would like to have a spare with me at all times. Do you have the OEM part # for a stock belt.
Sup yall,
Newbie here.
Is there any tutorial I can get for changing the supercharger belt and other basic maintenance???
I'm new to the E55 game. I just bought a 04.
Thanks!!
Newbie here.
Thanks!!
2015 S212
I'd be happy to show you how to take the belt off, but I don't mess with much else (maybe oil). The belt is too simple not to change out from time to time. I'll try to post some pics, since that is much easier.
2015 S212
I'm thinking about going with a slightly shorter one, so that it is a bit tighter. Right now, I am barely using any of the play in the tensioner and it slips really bad. Not just when I punch it, but even when I lift off.
Jangy, don't you have a pulley kit? If so, what size of belt do you use and made by which co.? I ask b/c I have a Kleeman pulley and would like to change my belt this weekend. Thanks ahead for any response.
2003 E55 AMG
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Don't you have the VRP belt tensioner thingamig or is that JRocket?...or some other mbworld guy with a J...
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Reviving this threat.
I have, what I think, is a belt slip on a Supercharger. Please correct me if I'm wrong.
After a hard acceleration, when I lift off the acceleration pedal car jerks once. It doesn't happen every time, and at times it happens with regular acceleration.
Both belts have been replaced and have less than 1k miles on them.
I'm new to M113K platform.
What could it be?
Thank you in advance.
What could it be?
What could it be?
What could it be?
Muhtish (05-05-2021)
Grab a belt-wrap
Man, for those dollars you can have yourself a belt AND a belt-wrap kit. The belt-wrap will take you from 45% up to 75% purchase on the supercharger pulley which will allow far less slippage and maintain boost. You will notice an instant improvement with a tighter and more responsive acceleration. With so much torque produced at the supercharger I don't think most people are aware how much belt slippage actually occurs when you plant your foot... ![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Just noticed the dates... oops!
I still suggest the belt-wrap though, works a treat.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
