*** STAR Diagnostics available at VRP ***
Subscribe
Mar 20, 2008 | 01:39 PM
Quote: How does this lowering fair to RENNTech ELM? Anyone?
With the SDS aka Star the car can be lowered aprox 1 and 1/4 inch..
the settings are set ...
With the ELM one can lower the car lower the car aprox 1 1/2 inch
one can change the settings as needed
Reply 0
Mar 20, 2008 | 02:18 PM
Quote: With the SDS aka Star the car can be lowered aprox 1 and 1/4 inch..
Settings are SET until you hook up computer right? I work in the comp field, I can prob keep a little laptop hooked in. its WAY cheaper then RENN ELM
Reply 0
Mar 20, 2008 | 03:58 PM
Quote: Settings are SET until you hook up computer right? I work in the comp field, I can prob keep a little laptop hooked in. its WAY cheaper then RENN ELM
One WILL Need a SDS aka Star and OBD 2 Cables to access the menu via the Mercedes Multiplexor to change settings...Without the Multiplexor one cannot get into the Menu
If You Do figure out a way to access the Menu WITHOUT the SDS please do share the results!
Reply 0
Mar 20, 2008 | 09:23 PM
..........I am a bit suprised they are just getting Star program now. No insult intended, but with all the work they do I would have thought that the first thing to get is star program. What have they been using all this time? An off the shelf OBD2 scanner like the rest of us?
Ted
Reply 0
Mar 20, 2008 | 09:53 PM
lol.. No Ted.. We just got a second one so we can have one in the California shop and I can keep one up here with me.
I've had an SDS for a while.
Quote: ..........I am a bit suprised they are just getting Star program now. No insult intended, but with all the work they do I would have thought that the first thing to get is star program. What have they been using all this time? An off the shelf OBD2 scanner like the rest of us?
Ted
Reply 0
Mar 23, 2008 | 11:08 PM
Quote: Vadim,
Is the $110.00 for mods 1 through 5? Interested in 1, 2, 3 and 5. Can you shed some light on 3?
did i miss a reply
Reply 0
Mar 24, 2008 | 12:53 PM
  #32
$110 covers anything one wants to do to their cars through STAR. Additional $65 is for lowering, as it adds time in measuring and confirming corner heights.
Reply 0
Mar 24, 2008 | 01:04 PM
  #33
Vadim:
What is "change spark timing settings" (item no. 3)?
What does it accomplish?
--Mark.
Reply 0
Mar 24, 2008 | 06:19 PM
  #34
Depending on the model there are 3 or 2 timing maps that are for different grade of gas 89, 91 or 93. On some cars it is "base" vs. "premium".
Reply 0
Mar 24, 2008 | 11:26 PM
  #35
Quote: Man. We need a VRP in NY/NJ area....
or somewhere near VA PLEASE!
Reply 0
Mar 25, 2008 | 03:46 AM
  #36
ASP+octane/timing=?
Quote: Depending on the model there are 3 or 2 timing maps that are for different grade of gas 89, 91 or 93. On some cars it is "base" vs. "premium".
What timing/octane should I use if in socal w/ ASP non-tuned?
Reply 0
Mar 25, 2008 | 12:37 PM
  #37
With CA 91 use base.
Reply 0
Mar 25, 2008 | 01:47 PM
  #38
Quote: $110 covers anything one wants to do to their cars through STAR. Additional $65 is for lowering, as it adds time in measuring and confirming corner heights.
not bad...
Reply 0
Mar 25, 2008 | 04:13 PM
  #39
Does it need a wheel alignment after lowering the car with STAR?
I have on 04 E500 can you enable:
- seat belt reminder? doesnt beep or anything when you unbuckle while driving (driver & passenger side).
- no trunk open reminder.
or perhaps this is normal in the 04's.
- adjust easy/exit feature threshold on the seats. I want it to go backwards all the way.
Reply 0
Mar 25, 2008 | 06:20 PM
  #40
Roehl: Each model is different and I can not see what can be done until STAR is plugged into the car.
You are welcome to come by and we can see what can be done.
Please call in advance.
Thanks,
Reply 0
Mar 25, 2008 | 07:09 PM
  #41
Quote: lol.. No Ted.. We just got a second one so we can have one in the California shop and I can keep one up here with me.
........makes sense. I was gegiining to wonder how you guys were doing all this fantastic work with a simple OBD2 scanner.
Ted
Reply 0
Apr 15, 2008 | 04:59 PM
  #42
do you also do ECU update? I was kinda thinking, if the dealer updates my ECU all these changes done (10C, chirping, etc.) will revert back to default?
Reply 0
Apr 15, 2008 | 07:15 PM
  #43
Roehl, yes we do ECU updates through our partner Powerchip.
As far as dealer reflashing your ECU, we can flash it back to your settings.
Reply 0
Apr 15, 2008 | 10:33 PM
  #44
I wish you guys would open a shop in South Florida, there are a bunch of AMG's down here.
Reply 0
Apr 15, 2008 | 10:53 PM
  #45
I'm working on it.. it's next on the list.. We have representation down there but its in Tampa.. C2Designs in Tampa does alot of VRP installs..
We've got California, Houston and Detroit covered so far.
Quote: I wish you guys would open a shop in South Florida, there are a bunch of AMG's down here.
Reply 0
Apr 15, 2008 | 11:11 PM
  #46
Quote: I'm working on it.. it's next on the list.. We have representation down there but its in Tampa.. C2Designs in Tampa does alot of VRP installs..
Tampa is pretty far from me im closer to Fort Lauderdale and Miami. There really arent any MB shops down down here besides renntech.
Reply 0
Apr 15, 2008 | 11:16 PM
  #47
Is there any vacant land or building across the street from Renntech?? I think that would be an optimal place to put a VRP building..
Quote: Tampa is pretty far from me im closer to Fort Lauderdale and Miami. There really arent any MB shops down down here besides renntech.
Reply 0
Apr 15, 2008 | 11:20 PM
  #48
Quote: Is there any vacant land or building across the street from Renntech?? I think that would be an optimal place to put a VRP building..
HAHA im sure there is. There are a bunch of warehouses in that area.
Reply 0
  #49
+1
Reply 0
Apr 16, 2008 | 08:54 AM
  #50
how about the nations friggin capitol!!! 2 richest counties in the usa are fairfax and loudoun. what am i missing vic ole pal. your prices are sick btw.
Reply 0
