Reset service indicator on 63's
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
I am servicing the car myself and need to reset the service indicator. I have searched and found instructions to reset on the 55 models but it did not work on my car. Has anybody successfully reset it on a 63 model? Thanks
2003 E55 & 2014 GL550
Hey cool, the search button actually does work. I was curious so I did a quickie search and the C guys are able to do it.
Check your manual and let us know if it says anything about it too.
In my 2003 C-Class Sports Coupe Operator's Manual "USA Edition A 2003" I found the instructions in the index under Service: Service indicator (226) Clearing (226,227)
Resetting is actually what you want, pp227.
Here's the short version:
In the event...service not carried out by MB Center...
>Switch ignition on (don't crank it though, like checking your oil)
>Press the ^ or down on the steering wheel until FSS appears
>Press the reset knob for about 4 seconds
[displays a reset question](let go of the button)
>To confirm hold the reset button again for about 4 seconds
[displays new reset interval]
07 CLS 63
https://mbworld.org/forums/cls-coupe-c219/234189-reset-service-c.html
Good luck.
I did mine couple days ago using the quick 3 reset push method. See my post on the CLS forum below...
https://mbworld.org/forums/showthread.php?t=234189
Good luck.
Good luck.
