Offset Question - PLEASE help...
Old Apr 15, 2008 | 01:20 PM
efivefiveamg's Avatar
2004 E55
I am seriously considering buying these rims:
http://cgi.ebay.com/ebaymotors/ws/eB...220382147&rd=1
Wheels specs:
20x8.5 et28mm (or 32mm for front) and 20x10 et42mm
Admittedly, I don't know much about proper offsets. PLEASE tell me if this rim will work on my 2004 E55. I plan on lowering with Renntech ELM just enough to close the gap.
TIA...
Old Apr 15, 2008 | 01:31 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
As Jangy... he's the offset master.
But AFAIK, if the front is 32, it should be fine. The rear may be an issue... may rub the inner fender.
Old Apr 15, 2008 | 02:22 PM
2004 E55
Thanks, I sent Jangy a PM.
Btw...IIRC these wheels were posted here a few weeks back and some members may have purchased them.
If so, please post pics!
Old Apr 15, 2008 | 07:24 PM
2004 E55
Bumpity bump...come on fellas, I need your input
Old Apr 15, 2008 | 09:52 PM
jangy's Avatar
2015 S212
You won't have an issue.
The front may be slightly too agressive. Worst case, you could shave some of the inner wheel. It all also depends on the tires you run. The overall diameter better be the same or smaller, or the front will rub.
The rear, 42 is actually pretty deep in. It will be fine, even with 295s. Again, the overall diameter matters, but not as critical as in the front.
Old Apr 15, 2008 | 10:26 PM
2004 E55
Thanks, Jangy.
One point of clarification though. What do you mean by the front needs to the same diameter? Same as what? Please excuse my limited knowledge.
Thanks!
Old Apr 16, 2008 | 07:15 PM
jangy's Avatar
2015 S212
Same final overall diameter as the oem setup. The new rim and tire MUST be very close (in height, not width) to the OEM setup (245/40/18) to make sure that you do not rub. The fronts rub on the very top and when you have the wheel turned.
Hope that helps
