Tire pressure at the DragStrip?
Hey guys, I'm going to the dragstrip next week and was wondering what the optimal tire pressure I should run on my 265 PS2s? Any recommendations would be helpful.
Thanks Guys
Dominic
Thanks Guys
Dominic
Turbonetics G35
A little OT, but what should the pressure be at for normal driving, the dealer gave me the car with like 34 pounds in the tires, but the door says it should have 46 in the rear and 41 in the front. (for a E63 btw)
'10 Porsche Turbo PDK, 500e, GL450
my understanding
is that if they aren't drag radials you definitely do NOT want to reduce the tire pressure too much from normal. Maybe a few lbs lower at most.
I experienced this myself on pilot sport cups. I reduced the tire pressure to low and it messed up the tire big time.
on our cars, this is correct...and not only correct for street tires but for d/r's as well. with the heavy weight our cars have, too little pressure will distort contact patch and decrease traction.
I have run 275/40/17's as low as 18 PSI for an autocross, and at the drag strip. in NO way did it hurt the tire/rim/car. Please explain how it hurt the tire "Big time" I am really curious on this my friend. Although, I have NEVER liked Michelins period so I would not stand up for their consrtuction to begin with. But I would like a little more info here please.
Loosing air pressure allows the tire to flatten out, ie making MORE contact patch, hence BETTER traction. YES it will reduce your load capacity, but we are not talking about towing here. Just remeber to pump them back up on your ride home.
See yeah
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
WHY![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
See yeah![drive](https://mbworld.org/forums/images/smilies/driving.gif)
See yeah
and for those that profess very low pressures, we're not running old bias ply tires with a 70 series sidewall or even a tire that has a small enough or soft enough sidewall to wrinkle with the lowered pressure. so what's your reasoning for lowering pressures (besides the fact this was what your father used to do in the 60's
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
why
See yeah
Both the rears went flat with damage to the sidewalls. So thats what I meant by hurt the tire BIG time.
Thanks for the explanation. Although I have personaly done this with MANY different brands, I am still suprised that it happened to you. Sorry for the bad time my friend. I would have suggested a call to the manufacturer if these tires died from this low pressure, as I am sure you could have atleast received a free set.
BFG has replaced tires for me, even after raod racing on them, because of scalopping. That is cutting out of the sidewall.
Chiromikey:
I understand that you meant MODERN tires, heck I am not that old my friend. And I too was talking about MODERN tires that I have used at the drag strip. BFG, Goodyear, Hoosier to name a few. Your tire annalogy is slightly off my friend, IF your tire is properly supported by the proper rim width. You are correct that under SEVERE underinflation, the center of the tire would tend to push up, and the opoosite effect under HIGH pressure. However real world physics cut in hear and the tire, if mounted on the proper width rim, would in deed flatten out giving a LARGER contact patch, yes even with a VERY stiff sidewall. All that I ask, before the huge debate, is try it out for one pass. I am telling you that my stang, set up for raod racing, could cut 1.80 0-60 times, on street tires, running about 20 psi. Every 4-5 psi increase cost me about .1 secondds. Please try it, you will not be dispaointed my friend.
See yeah
'05 C55(sold)'05 E55(sold)'06 911C4S(sold)'06 ML350 '06 CLS55(sold),buncha slo bikes
I make a baseline run with stock psi,then MAYBE drop down to 35psi in back.I will inflate fronts to 50psi once at the track.
After 70 trips down the dragstrip thus far,I find 35-40psi in the rear works best for my particular car
Chiromikey:
See yeah
So I am getting mixed results here, for some people low 20 psi works, and for some 30-35 psi works. I guess I just got to go out there and try it for myself and see what works for me then.
actually i have tried it...many times. this is how i know what works with my car. maybe i have something special.
i'm not interested what works for mustangs and the set-up i used in my camaro doesn't work either. in my e55 i cut 1.71 60ft times on 19" street tires at 30-34psi. if you can beat that in an e55 i'll go through my tire psi tests again and we can compare notes.
See yeah
