Resetting Service Indicator
Old May 20, 2008 | 08:01 PM
jpohl402's Avatar
E55 then E63, now back to an E55
I did search, but came up with three different answers.........
05 E55........
I don't want to clear the trip odometer by pressing reset button, help! Thanks!
Old May 22, 2008 | 06:52 PM
jpohl402's Avatar
Choices
https://mbworld.org/forums/showthrea...ight=reset+fss
https://mbworld.org/forums/showthrea...=service+reset
https://mbworld.org/forums/showthrea...&highlight=fss
Old May 22, 2008 | 08:40 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Here's what I got.
A1p13 Multifunction display A1s3 Trip counter reset button S110s1 Scroll forward/back button S110s3 System select button S111s1 Buttons + and -, setting of specific functions and volume control Adjust
1 Switch on ignition 2 Press the scroll forward and backward button (S10s1) repeatedly until the service date is displayed in the multifunction display (A1p13). 3 Keep the trip odometer reset button (A1s3) pressed for approx. five seconds until the "SERVICE MENU" appears in the multifunction display (A1p13). 4 Using the + and - button, setting of specific functions and volume control (S111s1) select the menu item "CONFIRMATION" 5 Press system selection button (S110s3) to confirm. 6 By pressing the system selection button (S110s3) select menu item "CONFIRM" 7.1 By pressing the + and - button, setting of specific functions and volume control (S111s1) highlight the engine oil grade used. In vehicles with engine 112, 113, 271
  • "STANDARD OIL" or "OIL QUALITY 229.5".
8 Press system selection button (S110s3) to confirm.
  • The message "SERVICE CONFIRMED" appears in the multifunction display (A1p13).
9 Press the system selection button (S110s3) repeatedly until the standard display appears in the multifunction display (A1p13). 10 Switch off ignition
