belt wrap kit feedback???
my idler pulley is starting to give out so i'm finally going to install the vrp wrap kit that's been on my shelf for a while now.
...so for those of you who have installed one, do you have any info on hp, afr's, boost, or any other input before i install? also, does anyone have the installation instructions that they could post or email me?
2003 E55 & 2014 GL550
I know you are a heavily modded guy like me Mikey, if you have the little reservoir for coolant up top (mine came with the EVOsport kit) that has to be relocated.
If you still have the res in the trunk, nevermind.
Shooting you over instructions on your email Mikey.
Don't have any performance numbers for ya on it.
oh well...anyone want to buy a brand new belt wrap kit?
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
'11/E63-Former car: '05 RT4 E55, Sprintbooster, Phenolic Spacers, RT IC /Secondary HE & BMC Filters
mixed. know one of our fellow members who took his off as had issues. maybe isolated case, but just passing along what i know. good luck, Mike.
Former Vendor of MBWorld
W211 E55
TIA.
EDIT: found it: https://mbworld.org/forums/showthrea...ht=tanks+surge
Mike...I didnt have any probs when I installed mine with ASP pulleys...
One porbs I had was TOP pulleys makking noise (then bearing had to get replaced)...but after I replaced the bearing it the noise didnt disappear but the bearing was pretty bad...make sure you install all the spacers with the kit...
http://ru.youtube.com/watch?v=9nuo2YkkorM
I dont know if worked or no...honestly didnt feel any diff...only my belt would last...and didnt get ribs burned...
I think Victor has all detailed instructions, ask him he has sent them to me bofore...
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i have one installed with pulley noise. i am still waiting to find out which pulley is the problem. any hints will be appreciated. others i talked to have had no pulley noise.
I do have a pretty loud screaming from one of the pully bearings. My mechanics says it is the the right pulley as you face the car just under the S/C clutch. They tried cleaning it but that didn't help. I contacted Victor, still waiting for some help.
May be its even you stock pulleys...
Put some oil into the bearings on diff pulley to see if the noise goes away ...
For you guys that just have noise when cold, are you concerned that sooner or later the bearing will always make noise and then fail?
2003 E55 AMG
I wish I could help out further guys.. I just dont have any spare parts.. they are all with Finny in Australia.. He's been hard to reach lately.. I am sure he is burried with his new business back home.
I'll see if I can get some spare parts sent over here that way we can address the issues..
Just PLEASE be careful about how much tension/preload you are putting on the aux tensioner.. if you load it up too much, it will put alot of stress on the bearings and cause them to wear prematurely.
The belt should be snug but not so tight that it has no movement.
