coolant level message ??
Old May 25, 2008 | 12:22 PM
mht_v10's Avatar
w211e55
I had the message coolant level light on, then I pop the hood then top off the coolant.
I never had any leak before, but after I top off the coolant a couple days ago, I didn't drive the car until this morning, I found there was a pond of water underneath my car ???
is it because of an excess fluid from the coolant or possibly a leak ??
argggh ....no service open on sunday and this coming monday won't be as well.
Old May 26, 2008 | 11:12 PM
juicee63's Avatar
2011 twin turboed prius
Make sure cap is tight and check the overflow, should be a tube. You may have overfilled it . Hard to get a leak in the res it would need to be a cap or overflow issue. Check all your hoses, especially leading to the radiator
