*****KLEEMAN STAGE V RUNS ANOTHER 11.470*****ADVICE PLEASE!
Old Jun 2, 2008 | 04:09 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Better intercooler / going turbo is the only way things are going to get better from a "bolt-on".
Neither of these two are freely available or easily implemented.
The Renntech SLR style intercoolers are nice but not sure how they perform... not many guys have them.
So that leaves traction ... 16" rims with larger profile drag radials should help the 60' and get you to your target.
Old Jun 2, 2008 | 06:43 AM
E55 RUSS's Avatar
E55K
Bigger 175mm pulleys
Old Jun 2, 2008 | 12:00 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by stevebez
...So that leaves traction ... 16" rims with larger profile drag radials should help the 60' and get you to your target.
even that doesn't help like it should and i believe it's because of the new tq limitering software. my 60ft times are almost identical going from 19" heavy rims with street rubber to 16" superlight ccw's with d/r's.
Old Jun 2, 2008 | 12:05 PM
rflow306's Avatar
2005 E 55
Same here, just more consistent with the mt's at least for me. With the mt's small burn-out large burn-out same results dead hook. With the torque we make chiro we should be running high 1.5's, tcu/ecu.
Old Jun 2, 2008 | 01:56 PM
chiromikey's Avatar
100% agreed.
on one hand i hate this limiting software because i know i should be running better 60ft's than 1.69 but on the other i can appreciate not breaking drive train parts having already twisting an axle and wasting a diff! i guess we need to be careful what we wish for.
Old Jun 3, 2008 | 12:03 PM
higginsbeach's Avatar
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
Thanks everyone for your time and effort. All responses have been helpful. I have some of my thoughts on comments below. And ROCK, I put you in the GREAT DRIVER category!! Thanks Albert for comments too. For now, I am going to get a Q LSD and MOTHER NATURE to get me my .15 tenths. I realize the Q LSD wont give me more HP or TQ, but perhaps a tad better on the launch and more importantly, save my rear end.
Originally Posted by Tech-Tune
Geez, I wish I had those kinds of problems...
Thanks Alex and I will keep you in mind about my CAMS if I change my mind.
Originally Posted by RippedUpMan
Have you thought about installing the VRP intercooler / heat exchanger? I know the stock pumps are trash, and replacing with a bigger pump helps, but the stock heat exchanger is TINY!!! This may be enough to squeeze out the time you need. It will probably be the least expensive mod you make to the car. I think retail the "kit" sells for around 1500 or so. I am about to have one installed on my CL55. I will dyno before and after if that helps.....
J
Already have the CODE 3 Heat Exchanger whcih seems to work very effectively. Did 4 hot laps within 20 minutes and no decrease to ET's.
Originally Posted by juicee63
Awwwww pooor Kleeman car only running 11.47's LOL HAAAAAAAAAAAAAAAAA
comon bro, its all in the 60 ft time
You need to 60 like yer buddy Tracshun. 1.63 5/100ths= 4x by the end of the run .2 off 11.47 = 11.27
Your trap speed likely has topped out , unless you can run @-1500 ft Then well then you would already own the top spot
Juicee, I wish it were that easy. My beast is going to have a hard time doing better than 1.684, however, I will keep at it.
i'm not sure airbox/tubes are enough, at least i haven't heard/seen any evidence that they've been proven at the track and an lsd won't help either. imho, the only way to get lower 60ft times (and possibly et's) is to get rid of the tq limiters in the ecu/tcu and i'm not sure thats been track proven to be possible by any tuners yet (even though it's been claimed by most). a larger pulley might help a bit but the easiest solution besides the high dollar slr style coolers or n2o is waiting for fall and running in better conditions.
Mike, I am in your camp on this one. I thought maybe the Renntech or VRP airboxes would give me the need HP I am looking for but not sure for the BIG BUCKS, it would get me my .15 ET I am looking for. Sure would be nice if I could test drive one out and see if it would do it. Any ideas???
Originally Posted by Rock
More bolt-on crap is not going to help you Roland (If it can..... somebody please prove it).
A perfect launch and the right weather conditions may get you there so I would focus on those two things.
DJ and Albert ran those 11.3's some time ago and that was before Albert had cams and I think DJ only had headers/pulley/ECU.
Listen, it all comes down to driver skill when trying to get the best et on motor only (That's why I can only muster an 11.7......I have none).
So what's moral of the story? A modified E55 (Headers/pulley/ECU + whatever other crap you decide to bolt on) is an 11.6-11.9 sec car @ 120-124mph. A modified E55 (Headers/pulley/ECU + whatever other crap you decide to bolt on and great driver) is an 11.3-11.5 sec car @ 120-124mph.
Thanks for the complilment Dave. I may wait another year for more mods and give MOTHER NATURE a few more chances. It's the safest and least expensive way to go for now, although the Q LSD is a must for me before i go to the track again.
I am going to stay away from a larger pulley. No more heat and stress on the engine for me.
Old Jun 3, 2008 | 12:33 PM
  #32
blackbenzz's Avatar
haters crazy
Cheapest and easiest answer is weight reduction.
I am gunning for the same time you are. I really want to pull the trigger on the VRP cams but I'm a little weary. Lets see if some weight mods and 1.5 PSI of more boost can cut .14s off my time Also gonna get some smaller drag wheels with mt et streets this time. When I ran the 11.48 I had an advanced auto battery (heavvvyyyyy) and a full nitrous bottle in the trunk.
Old Jun 4, 2008 | 03:05 PM
  #33
E55 RUSS's Avatar
E55K
+1
