VRP Belt Wrap Kit Screaming....New Bearing?
Old Jun 25, 2008 | 10:06 PM
dsc's Avatar
dsc
2004 E55
My VRP Belt Wrap Kit is getting worse and is screaming loud all the time. The bearing is shot. Before I trash the kit do any of you other guys with the kit know where I can get a replacement bearings?
Old Jun 26, 2008 | 12:02 AM
DFW01E55's Avatar
'14 ML BT
What did VRP say about it?
Old Jun 26, 2008 | 06:56 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
I would call VRP. If they can't help, then remove the offending bearing and take it to a bearing supplier. They should be able to pull the number and fix you up.
FWIW, I just had the same issue with my stock idler pulley and it is being replaced at the dealer.
Old Jun 26, 2008 | 07:42 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
which pulley is making the noise. is it the idler pulley? or which of the vrp pulleys is noisy. i have the same at start up but it quiets down. thanks
Old Jun 26, 2008 | 10:29 AM
Vadim @ FD's Avatar
S600TT, R350
dsc:
Our apologies for the trouble.
Do you know which pulley it is?
Old Jun 26, 2008 | 02:41 PM
dsc's Avatar
dsc
2004 E55
Originally Posted by Vadim @ VRP
dsc:
It's the bearing in the pulley that is located just below the S/C clutch (or as noted in the installation instructions, Photo D, Item 5).
Victor asked me to remove and clean the pulley & bearing, that had no effect. He asked me in conjuction to his efforts, to contact Finny but I can't get in touch with him.
Old Jun 26, 2008 | 06:20 PM
Vadim @ FD's Avatar
S600TT, R350
dsc:
If it is not too much trouble, can you look at the bearing and see part number is or take a picture?
I will get you a replacement.
Old Jun 26, 2008 | 06:58 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I am pretty sure this is the one you need DSC.
This is a pic from the pulley from my kit. This is the one that goes under the supercharger pulley.
SAYS NTN ON THE OTHER SIDE OF THE NUMBERS
Old Jun 26, 2008 | 08:04 PM
dsc's Avatar
dsc
2004 E55
Jackpro1, that sure looks like the pulley. Thanks.
Vadim, I appreciate the help. The kit is still on the car but I will probably take it off this weekend. I'll let you know when I do and post a pic of the bearing like Jackpro1 did.
Thanks guys!
Old Jun 26, 2008 | 10:28 PM
vrus's Avatar
2003 E55 AMG
Dan,
My sincere apologies for all the troubles. All of the spare parts are sitting in Australia with Finny so I dont have any spare pullies that I can send you.
I am in talks with a pulley manufacturer to make more copies of those aluminum pullies and I am trying to find a source for some replacement bearings to keep on hand in case anyone needs them.
I will get in touch once I have some solid info for you.
Old Jun 29, 2008 | 11:46 AM
E55 RUSS's Avatar
E55K
I had that porblems...the bearing was bad ...we replace it but the noise didint go away...then we found out that 2 bottom stock pulley went bad as well...but the noise was still coming from top pulley
Old Jun 30, 2008 | 12:25 AM
03e55's Avatar
03' E55
That is a Billetflow you could get a replacement from them.
http://www.billetflow.com/index2.htm
Old Jun 30, 2008 | 01:39 AM
psk145's Avatar
2006 E55
I've got a squeel at low speeds. I thought it was the sc clutch, So I had or replaced. Still have it though, so now I think maybe one of the idler pullies. I'm just worried the dealer won't fix it because of the renntech pulley.
Old Jun 30, 2008 | 09:11 AM
dsc's Avatar
dsc
2004 E55
dsc:
Vadim, do you have a bearing now or should I wait to remove the kit?
Thanks everyone for the input.
Russ, did you replace the 2 stock bearings or the whole stock pulleys? After which, did the noise completely go away?
Old Jun 30, 2008 | 09:46 AM
jangy's Avatar
2015 S212
The clutch doesn't squeel. I'm wanting to replace me OEM pulleys with some undersdrive ones, so maybe thats a way to cure and upgrade??
Old Jun 30, 2008 | 12:01 PM
E55 RUSS's Avatar
E55K
I didnt replace anything cause people from Kleemann DK sent me wrong pulleys and then I sold the car...but those bottom pulley cost here something like 280 EURO...
Another thing is that...my noise was only when the car was cold and afterthe car warmed up the noise disappreared so it could be a belt as well...Also when the kit was installed 1st... I didnt have any noise...so its really confusing what causes this noise at the end...I guess you have to inspect all the pulley and replace the ones with bad bearings on wrap kit and whole pulley if its stock...
Old Jun 30, 2008 | 12:16 PM
psk145's Avatar
2006 E55
well, it started as a squeek, but it's now progressed to more of a longer squeek/squeel. But its all good, I got my clutch upgraded anyway
Old Jun 30, 2008 | 01:12 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
my experience
doesn't have to do with VRP's belt wrap kit but it does have to do with pulleys and belts.
I've had the idler pulley replaced and that type of squealing doesn't go away with heat.
I've had squealing that came from a belt being too tight ... this one does go away after the car has been warmed up.
Point is there are many possibilities for squeal.
Old Jun 30, 2008 | 01:25 PM
jangy's Avatar
2015 S212
Thanks to me!! Its about time you listened...
Old Jun 30, 2008 | 01:26 PM
jangy's Avatar
2015 S212
What belt are you running, charles?
Old Jun 30, 2008 | 01:27 PM
RENNSTAGE's Avatar
im starting to hear alota issues with vrp stuff lately
psk145's Avatar
2006 E55
factory belt. I have a spare renntech belt in the trunk.
Old Jun 30, 2008 | 01:28 PM
psk145's Avatar
2006 E55
that day was the first time you told me fool!!!!
jangy's Avatar
2015 S212
LOL!! He has RennTech, but nice one. Hot over there?
Old Jun 30, 2008 | 01:29 PM
jangy's Avatar
2015 S212
What's the size difference? Its ok to run a smaller belt for a bit, but you'll stress all the bearings. You gotta make sure it is in the sweet spot of the tensioner. Grrrrrrr, I hate squeecks
