Improve you gas mileage by 20% plus
Old Jul 22, 2008 | 02:02 AM
Brabus E55's Avatar
E55
Originally Posted by Vic55
Beer is cheaper than Gas- Drink dont Drive!!
Old Jul 22, 2008 | 03:01 AM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
Originally Posted by Vadim @ VRP
The only concern about a switch - what happens if it the kompressor gets turned on at 80 mph?
I'm not really an electronic guy, but I was thinking maybe u can have 2 switches, each on either side of the seat. the only way to turn the S/C on/off is to press both at the same time.
Is it do-able?
Old Jul 22, 2008 | 03:08 AM
BenzoBoi's Avatar
Super Moderator
W221
Originally Posted by tbone
I'm assumin by the license plate frame that Peter did the wheels for that car...
Looks killer!!!
Old Jul 22, 2008 | 03:13 AM
tbone's Avatar
E500 Sport
Yup, Peter did that. Check out the lil 17" HRE's!
Old Jul 22, 2008 | 03:14 AM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
Originally Posted by III II I I AMG
no. 8 bucks barely get me a gallon of coronas.. at the clubs they're actually 4 bucks each.. so yea, id rather drive
drink sol instead
Old Jul 22, 2008 | 03:19 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
so where in the hell do the golf clubs go on these new fangled carts?
Old Jul 22, 2008 | 03:28 AM
  #32
tbone's Avatar
E500 Sport
on the ski rack?
these carts can go 0-60 in <5 sec with a bike motor inside:
http://www.smartuki.com/
Old Jul 22, 2008 | 08:00 AM
  #33
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
QUOTE=theeddie;2950098]drink sol instead[/QUOTE]
OK, Sol rules,
Old Jul 23, 2008 | 05:45 PM
  #34
Murtaza's Avatar
C63S coupe, X5M
Originally Posted by jangy
Nope, the baby is home. If you guys want to turn off the SC, why not just take off the belt?
I don't think anyone wants to shut off there SC...but having a switch would be handy when the car is in other hands or you're on a long trip and want +4 mpg. I don't think I could ever do the latter but it would be nice to have the option
The SC clutch is controlled by what, the ECU? It's set to engage at around 1200rpm? The switch would only have to tell it never to engage. I'm sure talking about is a lot easier then doing it though...
Old Jul 23, 2008 | 10:23 PM
  #35
jangy's Avatar
2015 S212
Yeah, they can play with when it engages but then you have to worry about the engine parameters at speed. the ECu would still assume it is getting the boost. You'd almost need two ecu setups... Either way, I think you guys just shouldn't let people you don't trust to drive your cars.
Old Jul 24, 2008 | 12:49 PM
  #36
III II I I AMG's Avatar
2003 e55
i never let anyone in my family touch it no matter how much of a emergency it is unless someone is passing away or whatever... valet, i just tell them to let me park it myself
Old Jul 24, 2008 | 01:39 PM
  #37
Murtaza's Avatar
C63S coupe, X5M
BUT at expense of 250HP.
I thought without the SC the motor is worth around 350hp and not 250hp?
Old Jul 24, 2008 | 02:21 PM
  #38
Vadim @ FD's Avatar
S600TT, R350
Without boost it is a 9:1 CR 5.5L that has to breathe through a blower.
Old Jul 24, 2008 | 08:48 PM
  #39
Chargin55's Avatar
2003-E55 2011-C63 2016-C63S
Originally Posted by C280Sportster
Mad Max had the same switch!
Good one! Id say the E55 is just as thursty as Max's Interceptor too! Fuel crisis is not that bad yet... but a supercharger switch like Mad Max had would be the go if things get worse!
Old Jul 25, 2008 | 01:19 AM
  #40
ama262's Avatar
(White) 98 CL500, (White) 06 E-class .. (White) 08 C-class and (White) ML63
com'on shutting down the Kompressor is like cutting off electricity. :s if you want to save gas millage you can but a corolla or something right???
plus if you can get E55 you might as well pay for gas with no problem .. unless the car is financed.
save 5 mpg is not that much of a deal but thanks for the advice man
Old May 26, 2009 | 08:19 PM
  #41
WL55's Avatar
E55
Was a switch ever made or figured out? Great Valet/other driver idea.
Old May 27, 2009 | 07:17 PM
  #42
Vadim @ FD's Avatar
S600TT, R350
That would be simple. Run an single pole switch to one of the lines to the blower and you are done.
You will get a CEL, if you run it too long. It will clear once the switch is back on.
Old May 27, 2009 | 07:44 PM
  #43
Vadim, what about the blower by-pass valve? How could we be sure it is open all the way, when the SC is off? Or is the ECU smart enough to think "I have the blower on, but I don't see boost, so I'll hold the by-pass valve open cause I think I've thrown a belt" After seeing the internal contacts in the by-pass, there is more to that valve than meets the eye.
Old May 28, 2009 | 02:05 AM
  #44
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
here is a better idea, why don't you just make the switch connected to the speed sensor ( like the TV one, ofcourse i removed it by going into the engineering mode ) but by this way
it will be assured that it will not turn on or off unless the car is in still mode.
Old May 28, 2009 | 01:26 PM
  #45
WL55's Avatar
E55
Thanks for the reply but what lines are you referring to? I'm new to these cars and still figuring out what's what.
Has anyone done this? Doesn't seem like a consensus on how to go about doing this.
