Blower idler pulley lose?
Old Jul 19, 2008 | 08:16 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Noticed the S/C belt was a little frayed pulled it off to inspect. I then noticed that the small idler pulley to the lower left of the tensioner seems pretty lose? I assume that is not normal. Is there a bearing part number to change this or have to get complete pulley from dealer.. Just to clarify, this is not the tensioner pulley. Tensioner seems fine.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 19, 2008 | 09:51 PM
jangy's Avatar
2015 S212
I think you have to replace the pulley.
Old Jul 20, 2008 | 04:08 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I think that one is an assembly, while you are at it consider the VRP extreme wrap kit.
This is Finnys engine and photo,
Old Sep 25, 2008 | 09:09 PM
PLATINUM SPONSOR
2003 CL55
From the design of this part, I think most should check thier S/C idler pulley for play , noise or failure.. My pulley bearing was actually spinning in the housing.
I checked with the dealer for my 03 55 and they say this set is like 360.00 bucks! I said, are you sure? Yes he said, and it has had like 3-5 design revisions..
Not sure what the new $360.00 set looks like but I just bought an off the shelf bearing and re-cut a new snap ring grove.. The bearing in the pulley was special made and a little wider than the off the shelf.. That is why I had to have a new snap ring grove cut in.. I am not saying this is the way to go but just pointing out a potential problem and my personal fix for it..
I started having issues with this pulley at only 29,000 miles. The 10mm bolt that bolts this set to the motor is long, leveraged and sloppy fit..
__________________
www.ultimatepd.com
Old Sep 25, 2008 | 10:27 PM
I Like Soup's Avatar
2003 E55 AMG
Yep, the pulley to the left of the supercharger snout was the one I had to have replaced.
Not sure about that wrap kit. It sure faded off in the sunset when people wanted dyno results, feedback, etc. I don't even see it on VRP's website for the 55.
