Auto taped colder Thermostat
PLATINUM SPONSOR
After installing a new I/C pump a week ago with stock thermostat ; results were. 14.5-16 deg timimg. engine temp 196-205 deg. and IAT would run 126-155. Did not like the 155 after 4 hard runs but they did recover quickly to 130 ish.
All runs both weeks were at 90-91 deg. ambient.
Installed new colder T stat and wow! Nice temp drop for this Texas heat. Average driving temp is 178-180 deg. and 190 after 4-6 hard runs.. What was really nice, was average IAT`s stayed 8-10 deg colder. 122 deg is my average in this heat now. On a full hard run, I would not exceed 138 deg verses 155 on stock T stat.. Timing seemed to hold very well at 16-16.5 deg.
Just need to get fans to come on sooner.
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
1 Post
germans
PLATINUM SPONSOR
I have the PTE (site sponsor) Tstat. I have used his Tstats in other cars. Always recieved a 1st class product and great service.
I may seperate the system some day but wanted to get general data and performance on easy cooling upgrades (pump, tstat and fan mod) first . Will add the Pulley mod in the next few weeks and see where I need to go from there. I am still doing searches and reading up on how much a seperate system really helps in hard numbers (not to easy to find this info).
__________________
www.ultimatepd.com
www.ultimatepd.com
if you are stock.. this solution will work.
Addinga a bigger pulley will require better IAT relief.
I still spike to 150F on a 90degree day.. but quickly cool down to 110F in a matter of 10secs or so.
www.mbworld.org/forums/showthread.php?t=241656
so does this T stat actuly work then? any otehrs tried it out & tested the results?
PLATINUM SPONSOR
Bottom line, my data shows a solid 10-15 degree average coolant temp reduction with the cooler T stat.. I would not want to run any cooler than that. I would like to see a quicker recovery from 196 when I reach that high, but will most likely need the 10 deg. fan mod to help that out.. Hope to have that mod soon and see what happens.
__________________
www.ultimatepd.com
www.ultimatepd.com
