Mercedes Bluetooth MHI Adapter
I'm not sure on the 63 but on the 55 the fuse for the module is in the engine compartment fuse box. It is a 7.5 amp fuse on the left side of the box were the majority of the fuses are.
i just installed mine in the pitch dark. the manual said it would start flashing faster once i pushed the button. which did nothing. anyhow...heres what I did..
1-pluged in the plug....make sure its aligned correctly. theres a little female grove on the car and a male grove on the bt part.
2--turned the ignition on and set the display to phone. the thing started flashing.
3-tried the button hold thing which did nothing.
4--enabled bt on my phone(i had it disabled) and searched for devices. low and behold--Mercedes benz blutooth device!!
5--paired the bt to my phone and tested it--worked fine.
if u have blue light try to pair. no light....perhaps u have the socket in backward.
hope this helps....
hope this helps....
I tried using my friend's brand new unit, and it light-up exactly like the manual said.
I'm going to try your method right now..... and I'll report back
It's not working. I'm pretty sure I have a defective unit. I bought it off E-Bay for $249. The seller has a very good reputation. He offered full re-fund of price and shipping. I'll keep hunting for another one I guess.
Thanks for your help though, it was worth a try
