Replacing headers - what's involved?
2004 E55 AMG
Looking at getting some short headers soonish - what's involved in replacing the stock ones?
Could an exhaust shop do it for me on a ramp? Or is it more involved?
Don't take it to Midas!!
S600TT, R350
Depending on the make. If they are like ours, than it will take around 4-5 hrs.
If they are more like unequal length where the bolts are hard to get to, add couple more hours.
Good Luck!
Good Luck!
Super Moderator
It'll look about like this:
https://mbworld.org/forums/w211-amg/208213-diy-header-install.html
VRP installed mine with nary a hitch. Alas, they’re a bit far for you.
A competent performance-oriented technician can easily handle the task.
Installing shorties is a DIY project if you're so inclined, but the time estimates given above are rather optimistic for a first time installer, whether he's an amateur or a pro. I did my Evo shorties in my garage, and I can assure you it took more than 5 hours, but then I wasn't doing it for pay, but rather for precision - like installing the new gaskets correctly and actually torqueing to spec the nuts and other **** things like that.
2005 E55
Installing shorties is a DIY project if you're so inclined, but the time estimates given above are rather optimistic for a first time installer, whether he's an amateur or a pro. I did my Evo shorties in my garage, and I can assure you it took more than 5 hours, but then I wasn't doing it for pay, but rather for precision - like installing the new gaskets correctly and actually torqueing to spec the nuts and other **** things like that. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I'm planning on tackle the headers myself as well.
Thanks.
2015 S212
Everything is bolt off and then on, so the pain in the butt part is which header you go with. These bays are small and that was a challenge in finding a good design. Honestly, I think the "best" header would need the motor "shifted" from side to side to be mounted properly. Other than that, I don't see us being able to runn fat enough equal shortys.
If you DIY, consider using a lift. It makes a world of difference.
