Autoenginuity
Old Aug 1, 2008 | 07:20 AM
supre55's Avatar
E55
Autoenginuity
Anyone else have a hard time getting rpm to update more than once every second or two? Is there some special trick I am missing?
Old Aug 1, 2008 | 07:47 AM
DFW01E55's Avatar
'14 ML BT
I'm having a similar problem, the sampling rate is horribly slow.
I wondered if it was my laptop being too slow but it ran fine not so long ago.
There's probably something in an update to the product that slowed it down. I've been in contact with them an no improvement after their suggestions either.
Old Aug 1, 2008 | 11:52 AM
jangy's Avatar
2015 S212
I thought this was a thing that is from our OBDII ports? I thought somebody was saying that the sampling rates are just not enough for good data.
Old Aug 1, 2008 | 01:10 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
have you guys updated to the newest software? i haven't yet but i'm wondering if that may be the problem.
Old Aug 1, 2008 | 02:35 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I am running Auto-tap and also have the same slow update sampling (You are not alone. Even on the other cars. I just bought a newer version after 8 years and it is still sloooooow..Being hungry for infrormation, it is frustrating to only run two or so parameters per run to get quicker samplings.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 1, 2008 | 03:03 PM
supre55's Avatar
E55
IAT, timing, speed and others seem to update fine... several times per second from looking at the raw data in excel. I am going to try and un-install and replace with an older version to see the difference if any.
Old Aug 1, 2008 | 04:22 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
I switched to AutoEng from Autotap and it's light years faster, but yeah still kinda blows due to OBDII.
No idea why super slow reponse from RPM.
Try an experiment and just run RPM solo with NOTHING else and see if it is faster at all. If not, most likely the devils OBDII. Possible software though so worth a shot.
Can't wait for something new.
Old Aug 1, 2008 | 07:13 PM
Vadim @ FD's Avatar
S600TT, R350
The problem has to do with baud rate coming out of DME.
Several month ago, I spent 4 hours with R&D engineer from Innovate, trying to get it put out data faster. We tried different command strings and data formats. It would not budge.
New LM-2, by the way, is awesome.
http://www.innovatemotorsports.com/products/lm2.php
Old Aug 1, 2008 | 08:55 PM
PLATINUM SPONSOR
2003 CL55
That LM-2 looks great! Time throw out my"dial up" auto tap ..
Thanks for the info.
Old Aug 1, 2008 | 10:31 PM
chiromikey's Avatar
may want to consider autoenginuity. they will be incorperating star scan in the future!
Old Aug 17, 2008 | 08:27 PM
supre55's Avatar
E55
So I rolled back to version 5.4 from version 6.1 and the update speed is much better. Speed, RPM and IAT running all together update every 6/10 of a second... which is plenty fast enough for my purposes.
