e55 questions, thinking about pulling the trigger.
I checked out an 05 e55. I noticed that after nailing the throttle at about 40mph in auto mode the car obviously downshifts and takes off with great urgency. But I noticed that it wanted to stay in that lower gear after I let off for awhile. Is this normal? I had to lightly give it gas to shift up the next gear. Is that for spirited driving? Or is something wrong with the tranny or perhaps the tcu needs to be reset?
I know this has probably been covered many times but is there anything in particular I should look out for on an 05 model? The car looks very clean and drives well. How much does an average 100k warranty cost in Ca?
anyone?
E63 P30, CL500 Sport
Was the car in Sport mode or Comfort mode. If it was Sport mode, then the car will naturally try to stay in the lowest gear possible to optimize power and shift points, but if it was in Comfort mode, then it should've shifted up one gear rather quickly (unless of course you were really driving spiritidly for a while). These cars are equipped with an adaptive transmission. So the more aggressive you drive them, the more aggressive they shift and vise-versa.
2006 s65. Ford Excursion 6.0. Pontiac GTO convertible. Porsche 944 Turbo SCCA car. Wife-E550 and 968
1993 GMC Typhoon, 1987 Buick Regal Turbo T
While looking for my E55, I received a quote for around 2600 for an after market warranty. That was 3 years and 75K total miles. These were coming from non-MB dealers.
2003 E55 AMG
Ditto. I find that after driving hard, the car stays in "WAR" mode, and holds onto a significantly lower gear for 45 secs or so to see if we are in "have fun" mode or "go back to attempting to get 20mpg" mode. The reverse is also true. The first time you get on the car hard after driving like a grandpa for a while, the car will embarrass you by shifting out at like 4500 RPM for the first shift. As an aside, I suspect this is why the post "first run in with an E63" last week ended the way it did. A prob with these cars is that sometimes they are too smart for their own good, so you have to learn to be in the right tranny mode at the right time, right gear, and do a sneaky ECU reset, which supposedly works better on 55's than on 63's. Good luck with the purchase, and not to sound alarmist, but buy the longest extended warrantee you can find unless you are planning on modding.
When you say it shifts at around 4500rpm, do you mean not at full throttle? I have never seen my car not shift at redline when I have it floored, no matter what my driving habits have been. Sure, a little slower on the downshift, but after that, it goes like all get out.
2003-E55 2011-C63 2016-C63S
Car will hold gear is sport mode. As for power off line, I went through a set of new tires in 10,000 km. Now I drive c mode mostly just to conserve rubber and minimise S/C heat soak. If I want to light em up I put it into s mode.
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
Thanks for all the replies guys!
I just wanted to make sure it was normal. I don't remember if it was in comfort or sport mode. But I did mess with that button.
Talked to a service writer at benz dealer and he mentioned the 05's have the bugs worked out and he doesn't see them come in with any issues. He mentioned that they have never had a replace an engine or tranny on any Amg car.
What are you guy's thoughts on 03's and 04's? What can really go wrong that can be that costly?
Thanks for the great info! Don't worry about iman. He probably woke up with his g string on backwards.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
