Flaps in front of the intake tubes?
Old Aug 8, 2008 | 01:05 PM
ATKM5's Avatar
2005 Mercedes G55 AMG
A couple of days ago I got rid of the those plastic flaps/borders in front of the intake tubes that lead to the filter boxes. Driving the car for a couple of days now, it feels a bit more responsive. However it might be just the placebo effect. My question is however, I know a few of you did the same, are there any problems with getting rid of these plastic borders? It wont ruin the engine If I drive it in the rain, right?
Old Aug 8, 2008 | 01:25 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
All I noticed was a large collection of bugs/debris in the airbox.
One shop-vac later, all is well.
Old Aug 8, 2008 | 01:34 PM
TopGun32's Avatar
here is a another tip...
look at your front grill (top corner & passenger side).. you will notice 2 sections of the grill are covered with hard plastic.. basically blocking air going directly to the intake tube.
Used a shard blade and I was able to cut those pieces cleanly. The cuts were made from the back of the grill.
I also removed the plastic cover on the hood vents. Almost 6 months ago.. and no issues with rain, car washes or even additional dirt on the engine. Just takes off the screws.
Old Aug 8, 2008 | 01:39 PM
TopGun32's Avatar
the only way water can ruin your engine.. if it mixes with your oil.
Let's think this through..
if water was to get in to your intake tubes... it will need to go through your air filter.. if moisture happpens to get through.. by the time it gets to the throttle body is evaporating.. and by the time is makes it to your pistons.. is gone.
You would need a hose connected to your intake tube to really damage your engine.
TopGun32's Avatar
this only applies to E55 and probably E63.. not sure of CLS
Old Aug 8, 2008 | 01:50 PM
supre55's Avatar
E55
I removed these some time ago... the benefit, if any, will likely only come on at speed from the "ram air" effect.
Old Aug 8, 2008 | 02:20 PM
ATKM5's Avatar
Thanks for your help!
Old Aug 8, 2008 | 08:45 PM
str8ridin's Avatar
05 E55
If this was so simple, why didn't the manufacturer think of this? With all their expertise of building hundreds of thousands of cars for years and years, hours and hours in wind tunnels, millions in R&D and they forgot to remove those little flaps? Or did they?
Just throwing that out there.
Old Aug 10, 2008 | 01:09 AM
gonzjed's Avatar
germans
those flaps look well designed to be extra plastic don't they...
Old Aug 10, 2008 | 06:41 AM
blackbenzz's Avatar
haters crazy
Just a reason to charge more
Old Aug 10, 2008 | 07:29 AM
Fr33kn63's Avatar
E63 AMG
I did the same thing. Before I got my CF airbox I had just cut off the plastic flaps. After airbox I went back and cut out the plastic that is in the grill which also covers a large portion of the intake tubes. I think its more then placebo affect cause I swear I can tell a difference once moving slightly.
Old Aug 10, 2008 | 07:44 AM
OzE55's Avatar
2003 E55
I removed those pieces 2 years ago without adverse effect.
Old Aug 11, 2008 | 04:16 PM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
Umm, not exactly.
I've seen two ricer motors destroyed by hydro locking the engine with water picked up through a modified intake placed below the bumper. They tried to drive through standing water that was just a little too deep and instantly sucked up enough water to kill the engine and bend a rod.
Doubt it could happen to our 55's by removing the intake flaps but it can be done if you try hard enough
Old Aug 11, 2008 | 05:30 PM
blackbenzz's Avatar
haters crazy
Originally Posted by speedpeddler
Umm, not exactly.
Theres a huge difference between what you mentioned and what is being discussed. Of course you can hydrolock a engine if you try
Old Aug 12, 2008 | 11:41 AM
Not really.
The discusion was about the possibility of water entering the intake and damaging the engine. I agree it's unlikely under the scenario being discussed but it doesn't take a garden hose to kill your engine.
Just passing on knowledge gained at someone elses expense. The lesson being...don't place your intake down low in the car where it can suck up water.
Old Aug 12, 2008 | 02:49 PM
enzom's Avatar
2005 E55
Not really.
Agreed. That was the single reason I stayed away from the very popular and effective Vararam intake on my C5Z06. Intake ducts ran right to the front vents, about 6 inches off the ground.
Old Aug 12, 2008 | 08:01 PM
corgiman's Avatar
E55
You're second guessing a bunch of engineers here. You paid them $$$$ to design the best car possible......it's why you get a Mercedes in the first place
There's some reason those deflectors are there.
Old Aug 12, 2008 | 09:56 PM
Fr33kn63's Avatar
E63 AMG
If manufacturers made their products perfect the first time there wouldn't be any aftermarket tuners.
Old Aug 13, 2008 | 07:17 AM
OzE55's Avatar
2003 E55
That may be true but their design brief was for the car to cope under almost unimaginable, worldwide, conditions and without performance being the priority.
Old Aug 13, 2008 | 07:55 AM
supre55's Avatar
E55
Remember, you are talking to a group of people who second guessed the engineers' designs for the ecu, tcu, crank pulley, heat exchanger, intercooler pump, air box, air filters, throttle body size, cam shaft shape, header design, exhaust design, tire choice, brake materials, and differential designs to name a few. If the engineers did everything perfectly, why is there such a large market for aftermarket performance mods... irrespective of make and model?
Second guessing Mercedes' engineers' choices is the very way AMG began.
Old Aug 13, 2008 | 01:57 PM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
i just cut off the flaps today, i will tell if anything goes wrong, or if i notice a change in power
Old Oct 13, 2008 | 12:23 AM
str8ridin's Avatar
05 E55
eh, went ahead and cut the flaps a few weeks ago.
Now I'm thinking to fabricate an L shaped funnel to route the air better into the intake tubes. Has anyone done something like this?
OR
More extreme, but, replace our front grill with a mesh grill...
Old Oct 13, 2008 | 02:56 AM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
flaps
there is actually a compnay that makes ram scoops for our cars, rpi i think it is.
Alot of times manafactures do stuff like this to limit horse power to sell higher end cars. Look at the c63, there should be no reason why the car cant push 507 hp like the e63 and cls 63.
If the lower end cars with the same engine produce the smae HP, people would end up with the lower end cars for the HP
