New Shoes & Split IC
I also finally split my I/C circuit... which was somewhat of an ordeal. First, for those of you who have done this you know how tight an area we are talking about and how akward it is to get the proper tools along with your mits in that area. I can't tell you how many time I dropped a tool and then followed by dropping the f-bomb. Second, I could not cut off the oem clamps at the coolant/IC circuit "T" for the life of me. I finally had to simply cut the hose... which left me about 1/2" short to properly join and clamp the coupling. I had to go to Lowe's and buy a 6 inch length of 3/4" heater hose, another coupler and more clamps. By this time it is dark so I grab my trusty work halogen. I finally get everything clamped together, fill it (2007 5 series p/s reservoir) with water and it leaks like a freakin sieve.... there goes another bottle of water wetter on the garage floor. Looks like I will be scrubbing the garage floor later. I pull it all back apart, put it back together, and as I am re-tightening the clamps back I smell smoke. I look over through my sweat filled and blurred vision (100+ degrees in the garage even with the fans) and my halogen has tipped forward and its cage is now resting on the return brake line.. and it is smoking like like Tommy Chong. I take a closer look... awesome, its melted right through the brake line which now has a nice hole in it.
After cleaning up the brake fluid off my garage floor, re-splicing my brake line and re-assembling the I/C and coolant circuits for the second time I fill'er up... NO LEAKS!
A smooth and quick 7 hours after I should have been finished, I finally get to take few hot laps and IAT's average +11 over ambient and peaked at +37 over ambient on my fourth 0-80 run. It was 96F ambient at the time. I guess it is working.
Chris was supposed to split the circuit a few weeks back, but he called when I was 10 minutes away and had to cancel with some type of family issue. I was hoping to be able to have some type of reservoir within a reservoir. I could then pack the gap with shaved ice. I had a nice little drain line idea to keep the melt off from wetting the belts and everyting. Not near as cool as the trunk mounted system, bu still pretty damn nifty if you ask me.
Any input is appreciated regarding the rim weight.
How much of a difference is the split IC making? I've thought about doing that, maybe before next summer. I know Chris is shutting his shop down too but I'm hoping to stay in contact with him for these type of jobs (read: I don't wanna clean up my garage floor! LOL!).
Very nice.
Sorry bout the garage snags. Been there and done that.
I dont mind the star on the grill, its the thick black slats that look a bit out of place. I wonder what white slats would look like with the chrome and star?????
