Radiator leaking coolant into trans lines!
Anyone else have info re this?
Were you guys confident about saying that "anything with a build date after 2003/09 used the improved radiators."?
Therefore my Model Year 2004 car, build date 2003/08/29 has the problematic radiator?
Was it a fix for a 2004 model year car? or for the production month of September?
I would assume all 2004 e55 are the same in terms of the radiator and piston ring land updates?
https://mbworld.org/forums/e-class-w...ation-tsb.html
https://mbworld.org/forums/c-class-w...iator-r-r.html
Thereby causing numerous shift issues, or non-engagement issues. It's always best to replace all the clutches in the transmission.
Now if it just happened, you might be able to get away with just an extensive flush including converter.
They know how to fix it by charging INSANE amounts of money.....I should know, I work in a dealer and sometimes cringe at what I charge !!
