transmission valve body blow
2007 e63
well i have a 2007 e63 with 1200 miles on it the transmission stopped shifting,took it in to mercedes benz of anaheim,they said the transmission valve body blew,anyone else experience this problem?
1 Post
4 wheels
Early early E63's had some problems with the Valve Body. Its a very easy fix and the car will behave very much differently than it did with the old one. Don't worry about it.
Super Moderator
DTB P-B-27.60/88a
It’s a swell transmission – when functioning properly: http://www.mercedestechstore.com/pdf...9%20062504.pdf
722.9 Transmission Control Module is housed in the Valves Body. The failure could be a defective solenoid, rpm sensors or TCM. Its not a major failure, MB will order a new one and replace it. You should be back in the drives seat in no time
My CLS 55 (I believe its the same transmission) just was brought in for the same thing. They are replacing the entire valve body. I am interested in comments that fixing it will make the car feel different. Any reason why ? The transmission felt ok - except the once a week when it would shift into neutral.
2007 SL55 AMG
This is a thread from 08 btw
