Datalogger in hand
2015 S212
Datalogger in hand
Anyone in SD that wants to check out your car, let me know. I finally put some numbers to my IATs with and without the airtubes inside. max was 120 with and 170 without. The sad thing is it takes a while to cool off without them. I haven't figured out how to get A/F ratio yet.
K3 05 E55 sold, 09 GL550
Jangy, I lived on mountain ,in summer here in NM I got 95F or 100F all time and very humitt and my K3 E55 got 110F on high way and 115F on local . BTW I got spacers,PTE160F,C090 pump run all time , code3 HE and 120z water wetter mix with MB coolant . I think you should get CM90 pump and mix water wetter to the coolant to bring your IAT down , actually you got cooler air in so.ca .
1 Post
4 wheels
1 Post
4 wheels
Ah gotcha. you said mountains so i thought you might be from the ruidoso/carizozzo area. if you have time. be sure to check it out. beautiful place in the winter, especially ruidoso.
When I get my pulley back I might take you up on that offer. Can that thing check for boost? I am positive that my S/C shuts down, so I will need to so something about that, hopefully this can shed some light on what or how I can fix that.
Tried making a run to 140 one night in Mexico and the car just stopped accellerating at about 125ish... Extremely disappointing.
2015 S212
Anytime.
2005 E55 AMG
2003 E55 & 2014 GL550
Maybe not the best idea down in So Cal, but up here in the boonies, noone cares.
( I gave up as the readings coming off the O2 sensors are just voltage and or not very accurate from what I have concluded. Accurate meaning converting voltage to actual ratios. They WILL tell you if you are super rich or lean which is good)
I tried and tried to get a/f's but finally gave up and purchased the Innovatative Motorsports wideband that you clamp to rear tail pipe. It's radical as you have to drive around with wires and clamps hanging out of the back of your car, but works KILLER. I can hold the unit in my hand as I hammer it and watch a/f's change in near real time.
its not real time.. but records my daily commute.
IAT, engine speed, MPH, timing.
The boost feature is not very good.
I'm just worried about timing and IAT's at this point.
so far.. I'm in good shape. I hardly have ever reached 140F.. only if I hit 110+ on a 95 degree day.... but my recovery is pretty quick.
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Hey, question everyone:
I have a Carchip E/X, which I actually won back at CES 2007 because the our company's exhibition booth was right next to Davis and I got in one of their races and won this unit. My question is, I used the thing on my 2006 yukon xl denali and it worked fine. I want to use it on my E320 but noticed something interesting on the web site about cars excluded. It said that cars with tiptronic transmissions may experience stuttering if a carchip is used. Any of you guys have a problem with this? Are Benzes considered "tiptronic" because they are not like Audi's or BMW's in the design and functionality?
2015 S212
I don't think so, or I am so far removed from the BMWs. the last one I had was a 2000 328i and it had nothing under Drive. You could just go left and right.
Either way, I'd get more info about compatibility. Maybe you can contact the companies technical services to make sure it has been released for use on a benz. Or, at least make sure you have a plan in case something gets toasted.
