Taking the right path........
Old Oct 20, 2008 | 11:11 AM
HAHA BYE's Avatar
2003 E55 Blk/Blk
It shows a msrp of $262...
Old Oct 20, 2008 | 12:25 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Originally Posted by jangy
I agree that a CM30 is no better than the newer OEM bosch which (I can get for free. I wanted up in capacity.
Terrible info.
The OEM is crap, no matter how you slice it. The newest version lasted a whopping 3 months in my car.
The CM30 is a proven, reliable upgrade. If you don't think the flow is sufficiently improved over stock, you should unplug the bleed valve and see the stuff shoot across the garage.
Old Oct 20, 2008 | 02:14 PM
HAHA BYE's Avatar
2003 E55 Blk/Blk
Originally Posted by splinter
Johnson’s CM30P7-1 claimed flow is 26 liter/min
Stock is like 15-20 liters a minute flow, meaning the johnson cm30 pump is barely an upgrade in flow efficiency but merely an upgrade in reliability.
The davies pump is like 80 lpm...its a no brainer...ps its goona shoot across the garage regardless
Old Oct 21, 2008 | 12:09 AM
jangy's Avatar
2015 S212
Originally Posted by ChicagoX
Terrible info.
I never said the OEM one lasts forever. I'd bet you wired it to stay on, right? If so, then it explains your life-span on it. Everyone knows the CM30 is more reliable (lasts longer) than the OEM one but my car is under warranty so I can have as many OEM pumps as I'd like.
As far as flow, sure the CM30 is about 25% better than the OEM one. You consider that sufficient, I don't.
But that again, isn't the point is it? Let's review the facts:
The Davies pump is designed for this exact application with a hermetically sealed, brushless, and compact system. The ports are larger than even the CM90 and itis rated at 80L/min vs the 25L/min that the CM30 is. To top it all off, it costs $200.
So please go back to claiming misinformation, but get rid of those pumps ASAP!!
Old Oct 21, 2008 | 12:33 AM
ChicagoX's Avatar
W211 E55
The wiring is completely stock, right down to the connectors. Swing and a miss.
My car is also under warranty - but I refused the option of going through the same routine and took the path of least resistance for my application. Free isn't always better. Unless you like driving the C-classes given out as loaners...
I guess with all of your experience with upgraded cooling on these cars, you would have found out what a pain the larger orifices are to work with, and would have seen that the CM30 is sufficient to run an 11.41.
Old Oct 21, 2008 | 12:42 AM
jangy's Avatar
2015 S212
Hmmm, I'm out of ideas. Why do you think yours lasted so much less time than typical?
You got me there. I never had my OEM Bosch go out on me but I still wanted to upgrade so off it came.
It isn't about experiences. It is about doing something right, regardless of what was "good enough" for another guy. OK, the CM30 is plenty of pump for your application. But, many of us live in different conditions and chase different targets. To be honest, the larger orifices weren't that hard at all, since VRP had custom inputs, outputs, and tubing for this application. Now that i am playing with it, I am finding out that most other aftermarket brands are turning to the same things I am. Things change, Wayne. Having a different perspective isn't always bad.
Old Oct 21, 2008 | 12:49 AM
  #32
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
...the CM30 is about 25% better than the OEM one...please go back to claiming misinformation...
Per Vadim, “Johnson is smaller physically, but delivers 50% more flow (22.5 L/min vs 15L/min)” from his thread.
Old Oct 21, 2008 | 02:46 AM
  #33
HAHA BYE's Avatar
2003 E55 Blk/Blk
thats still tiny numbers. Yea the percentage sounds high but what does that really equate to and extra 7.5 lpm thats nothing. Sufficient isnt the same to everyone on here. The Cm30 is sufficient to run low 11 pass but what does that tell me about how hot the car is and how the next pass will be? You can run that stock after icing the charger...but only once...
Old Oct 21, 2008 | 04:43 PM
  #34
ChicagoX's Avatar
W211 E55
Judging by the debris in the pump itself, I would say it's a material choice.
I would opine that in severe duty (Chi-town potholes) apps, the vibrations cause damage to the brushes/magnets that leads to failure.
Every Bosch pump I've dissected had what looked like copy toner all over the windings and inside the housing.
Old Oct 21, 2008 | 04:49 PM
  #35
ChicagoX's Avatar
W211 E55
With higher flow, you will be pumping hot coolant back into the charge cooler potentially before you even complete the 1/4 mile. Dwell is a good thing for heat transfer. Also, the hotter the delta, the more efficiently the system works. Pumping warmer coolant faster won't necessarily make it perform better.
The real need is heat rejection, aka a larger Heat Exchanger. The E55s pull timing in three stages for both water temps and IAT. If you hit one half-degree over the threshold, you can say sayonara to up to 9.5 degrees of ignition timing and the power that goes with it.
Old Oct 21, 2008 | 08:20 PM
  #36
jangy's Avatar
2015 S212
All the more reason to go with a sealed, brushless pump, no?
Old Oct 21, 2008 | 08:23 PM
  #37
jangy's Avatar
2015 S212
You don't need Vadim to prove it. How the CM30 compares to the OEM is just trivia. Either way, we are all changing pumps and none of us is using the OEM so who cares how your candidate stacks up to it? The fact remains that the CM30 has always only been for those that only needed "sufficient" flow. The CM90 has always been for the hardcore.
Old Oct 21, 2008 | 08:27 PM
  #38
jangy's Avatar
2015 S212
That may be where we differ. You are into drag racing and 11 seconds is the realm that operates in. Actually, I agree with many of your comments taking that into consideration.
But, for me and many members, a single run means nothing. We are after more consistency overall, not just during a small window in time. Again, your point of keeping the cycled fluid out until after the run makes loads of sense and I could see where a higher capacity pump would do nothing (or even harm) your setup.
Old Oct 21, 2008 | 10:22 PM
  #39
HAHA BYE's Avatar
2003 E55 Blk/Blk
I agree with Chicago X that the idea is to get a larger heat exchanger but no Im not into drag racing Im into the realm of longevity. But Im more in Jangys boat of consistency. Jangy your sig doesnt help your point lol jk man. A pump with higher lpm mated to a larger heat exchanger that can cool faster is pure sex
Old Oct 23, 2008 | 06:31 PM
  #40
tracshun's Avatar
W211 E55
....But, for me and many members, a single run means nothing. We are after more consistency overall, not just during a small window in time...
...The Cm30 is sufficient to run low 11 pass but what does that tell me about how hot the car is and how the next pass will be? You can run that stock after icing the charger...but only once...
Not even remotely accurate. I have run "consistent" and "back-to-back" passes in my car at several tracks throughout the country with DAs ranging from -500 to +2500. All my runs have ranged from 11.6X to 11.8X (mostly depending on the 60').
A perfect example is when my car went 11.60 this month while it was on FULL BOIL. Here is the video: http://www.youtube.com/watch?v=_7SbHcg_rGY.
Yes, did the heat rob me of some trap speed. Of course. Find me a car where that doesn't happen. But, to say you CANNOT run back to back performance runs with similar times and traps with the CM30 is pure ignorance (no offense).
BTW, when I ran that 11.60, it was my fastest EVER run at the time. It was also potentially my hottest. Then again, I remember running higginsbeach at NED in May, back to back to back to back. And, yes the car ran 11.7X EVERY TIME. He is one of the later runs. http://www.youtube.com/watch?v=1Sh3Sluj_ko Notice how the commentator says, "he's doing better and better each time...". Keep in mind that was a stranger.
On that run (which I think was my 3rd or 4th in a period of about 10 minutes), my car ran an 11.75 at 117 and could not have been much hotter FWIW.
Old Oct 23, 2008 | 08:48 PM
  #41
jangy's Avatar
2015 S212
Huh? Who said that? I ran almost 50 runs in 100 degree weather with consistent drop off. So what? My last runs were my fastest, too. So what?
Not a whole lot to me, but maybe to others.
Old Oct 24, 2008 | 12:20 AM
  #42
tracshun's Avatar
W211 E55
You lost me....I thought that was the point of the last few posts (see your and haha's quotes in my last post above). Point is simple. CM30 pump is THE perfect alternative for these cars - RIGHT NOW. It is tried and tested. It is affordable. It flows MORE than enough, and in combination with a good HE, you can drive this car hard / drag race it through the desert (exaggeration) without any problems. Might there be another alternative. Sure. Might there be a better alternative in the future. You bet. But for now, I think the Johnson pump wins hands down. If I am not mistaken, it was you who took the bold position NOT to buy a "marine" pump for these cars, and that is just NOT good advice. Nor are your statements accurate for the vast majority of E55 users, IMO. Appreciate the banter and brainstorming though.
Old Oct 24, 2008 | 12:45 AM
  #43
jangy's Avatar
2015 S212
If not now, then when? The products are out there. You use what you like.
Old Oct 24, 2008 | 12:48 AM
  #44
c32used's Avatar
LET C32 2002
Old Oct 24, 2008 | 01:26 AM
  #45
tracshun's Avatar
W211 E55
Nope.
Old Oct 24, 2008 | 01:34 AM
  #46
tracshun's Avatar
W211 E55
This is your point, right?
Not a fact by any stretch. Merely a single unsubstantiated opinion which I have yet to hear anyone chime in to support.
Many "hardcore" owners of the 55k are using the Johnson 30 series with fairly heavy handed applications on their cars....with no issues. In fact, I can think of a few who are chasing the "all motor" 55k record with that pump and are doing just fine.
Old Oct 24, 2008 | 03:37 PM
  #47
HAHA BYE's Avatar
2003 E55 Blk/Blk
Nope.
I never said that the CM30 was not efficient but over time and a few runs the cm90 will out perform it. But only if the heat exchanger is capable too... lol Im not attacking the CM30 but Im one to go with new products that are meant to out perform the old ones with new innovation...Also the Cm30 isnt much cheaper than the davies $200 pump what like $25 cheaper?
Old Oct 24, 2008 | 03:44 PM
  #48
jangy's Avatar
2015 S212
They gotta sell what they bought...
Old Oct 25, 2008 | 02:15 AM
  #49
HAHA BYE's Avatar
2003 E55 Blk/Blk
amen
