questons re: lowering
Old Oct 22, 2008 | 10:27 PM
marcmc8867's Avatar
'15 S550 4Matic, '15 GL550, 360 Spider, Escalade ESV
I've been reading a bit in the archives about lowering the ride height on my '06 E55 via aftermarket ride height module or Star lowering.
Is an alignment necessary afterward? I would think it would affect camber and other settings...
How much lower would the end result be versus the stock "low" mode? Would the stock "high" mode be lost (and replaced by the modified high/stock low mode)?
Is the handling much improved or is the benefit mostly aestheti?
Thanks in advance.
Old Oct 22, 2008 | 10:33 PM
jangy's Avatar
2015 S212
Yes. These are not machperson struts, so the angles always change. Pick a height and have it aligned for that height to minimize wear.
You can easily lower it about 2". It is MUCH lower than the stock sport I and II modes. It just lowers everythying. Once lowered, raising the car gets it to about OEM height and the comfort, sport settings still do their thing.
Both. The module will lower the car beyond what is needed for handling. You will feel much better wheel response, turn in, stable ride, etc. It is all a compromise.
Old Oct 22, 2008 | 10:39 PM
marcmc8867's Avatar
Thanks for the quick reply.
So sounds like ride quality isn't compromised too much then...?
Has this cause people to have more issues with Airmatic? ...and thus warranty disputes? (I've got warranty thru 7/2010)
Old Oct 23, 2008 | 12:08 AM
OPALW208's Avatar
SL55, C63
there are 4 ways to lower your E55
1. Star lowering.
2. Mercedes OEM Links
3. ELM (electronic lowering module)
4. A combination of any of the above
if you want info on any of the 3, just shoot me a PM and I'll be more than glad to explain all the differences.
Old Oct 23, 2008 | 12:38 AM
jangy's Avatar
2015 S212
Issues..yes. Warranty issues...I dunno.
Old Oct 23, 2008 | 12:40 AM
jangy's Avatar
2015 S212
1. Star lowering.
Or the adjustable links
Or modifying your own links
All links suck (I've done them all), but for links i like the OEM ones off of the S series.
Old Oct 23, 2008 | 02:11 AM
HAHA BYE's Avatar
2003 E55 Blk/Blk
Whats that?
Old Oct 23, 2008 | 02:13 AM
jangy's Avatar
2015 S212
MB makes adjustable links that will fit. They were used on earlier model S classes.
