NEW larger ASP pulley!
Just recieved a new ASP pulley and they have have broken the 180mm barrier!! Of course I am always looking for easy eaxtra power. Not to mention, if headers and larger Tb really reduces some boost,, then this will help get it back!! We all like extra efficiency but deep down inside, we really do not want less boost ...
I can not wait to get this new ASP pulley on and test it out.. Speaking of test. I am thinking track test and using my weather station to get accurate D/A correction? Getting accurate dyno`s on a very heat sensitive car and on different days, is not fair test.. Hell, 20 deg. change in intake air temp can make a huge difference in power, especially if you go above 140 deg. (easy to do)..
What does everyone think before I take the other ASP pulley off and go 180mm plus?
Here is a quick shot of the new ASP next to my old stock pulley.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
WOW, now this sounds good for the bigger t/b and exhaust croud. Definetly do the ported blower with this design though. There is going to come a point when the stock blower becomes inefficent and creates more heat than usable power. Ported heads and blower with this pulley should have some interesting boost #'s, but they really dont matter if you cant use the volume of air to make power. This sounds like a step in the right direction though, just might take some tweaking to find the right combination 650 rwhp on boost alone anyone??? I think its doable
Ported heads, are a large part of my build plan.
Interesting, let us know how it goes. Im thinking about swapping out my old ASP pulley for the new one. Im assuming it comes with a new belt?
What is the size? Anyone have pics of the old vs new ASP, not OEM. There is not much room, so i assume they gave you a water pump pulley, too. If not, then I don't believe it.
Where is houston do you get your work done on your 55
__________________
www.ultimatepd.com
www.ultimatepd.com
by pass valve!!!
it would run open more often and bleed all your boost.
I would not do this.. until you get the ECU.
There is not need to add a pulley unless ECU is done to deal with the bypass valve..
last year.. I had a total different view on ECU tuning due to my C32.
But the C32 does not have a bypass valve.. so any mod to increse boots works just fine.
My wife bought it from ASP as ONE of my many B day presents.. They are located in a suburb of Houston.. Call ASP, they can give you details.. My wife won`t tell me the price.. I think it is the first or one of the first super pulley`s made so far.. I also bought my last pulley 6-7 weeks ago andlove it!
If so , then why does my boost after ASP pulley addition calculate to 15.2psi( based on formula from a sponsored site tuner)? Why did after the change , that I boiled my pilots off from no traction, in 95 deg heat with 28mph rolls? I then had to buy NEW wider/sticker nittos Invos just to help the problem.. Why also do my IAT `s shoot up from the heat of pure BOOST!!!!
by pass valve!!!
__________________
www.ultimatepd.com
www.ultimatepd.com
My wife bought it from ASP as ONE of my many B day presents.. They are located in a suburb of Houston.. Call ASP, they can give you detials.. My wife won`t tell me the price.. I think it is the first or one of the first super pulley`s made so far.. I also bought my last pulley 6-7 weeks ago andlove it!
I had my car dyno'd by Code3 (Brandon)
He had my car for 1 week to run tests with it. He threw everything at it.
No way around it.. needs tuning to put the bypass valve on check.
My car only dyno'd at 400RWHP and 450+ RWTQ on multiple of runs.
I can hear my bypass valve open even cruising.
Its making boost alright.. and your IAT sees it.. but it finds its way out.
In some cases ASP has made a bit HP and a lot more torque than my car.. but it depends on the Dyno machine, weather and ECU files.
I had my 2nd air flash done twice this year.. so I have the newest ECU.
On my C32.. there is no bypass valve.. you can pick up power just with a pulley.
it just adds torque at the lower revs and looses HP on the higher.
I hear you and that is why Dyno`s on these cars are really tough to be consistent or get peak numbers.. If the IAT`s feel it as you say ,, then boost is also there. Boost =heat.. My car pulls like a rocket up top now but let the track tell the truth..
Why would anyone be against me putting a larger pulley on and seeking max power? My money and my time.. Just sharing un-biased info ,results with ATAP and a good track close by..
you are running 20 wheels and show hp lower then stock... are you refering to butt dyno? (no offence here intended)
TopGun32 was an other beliver that the asp alone made a difference, until he did a bit of testing...
no offence Exotic-metal55 but a few members have assumed increase of hp due to asp install and have show other wise with out an ECU tune
unless your data shows other wise?
don't think anyone is againt you putting larger pulley on - I think TopGun is only trying to bring to attention that you gains are limited due to you lack of ECU tuning and espcially since the newer ECU map have an overboost protection
what performance?
I meant to say its "potential" ECU'ed performance. My point was if the new pulley is better constructed or it's same weld-on job as the old.
Yes I run on 20"s. You running 15" with slicks? Just wondering...
Lysholm vs Bell... Ding Ding.
Our charger is only efficient up to 175mm, then any extra power generated after via a larger diameter is parasitically reused to drive the charger and lost.
The only application that would benefit from a 180+ unit would be a 55 with the stock cooler removed to free up extra boost from the bottleneck.
Bigger pulley doesn't always mean extra power for everyone unfortunately.
A side by side comparison of the two pulleys would also reveal the figs.
A more efficient charger design would only benefit from a larger size pulley other than a 175.
See this comprehensive article with lots of photos which will put all into perspective...
http://www.kennebell.net/techinfo/fo...RvsLYSHOLM.pdf
Unfortunately our chargers are not the most efficient on the market. IMO the Kenn Bell units are the best, no BS.
A dream setup to give turbos a good run... Just add 185 pulley with SLR Coolers and a Kenn Bell 6x4 rotor charger as apposed to our mediocre Lysholm 5x3 design.
Seriously though if you want to add a 1mm here and get 1hp there thats cool, but if you seriously want to go nucking futs, do the above installation. I suppose it all comes down to Bux. (Bux = HP!)
So to the after market dudes... Whip up one of these kits and make a quid.
Now we have a winner...
Oh, one more thing... the recirculation throttle body or bypass valve, doesn't rob you of power. I'll write up the evidence with photos later on my current thread.
Cheers.
Cheers.
