E63 Renntech vs MHP data
Old Oct 29, 2008 | 05:37 PM
  #201
RHBENZ's Avatar
08 S550, 08 E63, other non-Green cars
Originally Posted by LZH
I'll wait for Andy to post and clear up the procedure for how they modify the TCU through the ECU - all I know is what he has told me privately.
Jangy - as far as your comment regarding the MHP gaining nothing - well, you are simply showing your ignorance. First becasue most of the gains were under the curve, where it really matters. Second, becasue it seems now the MHP ECU tune was not even loaded and the TCU tune alone beat the previous Renntech dyno !!!! LOL - you are lost bro.
So if the MHP ECU flash didn't take, why the dif in A/F? I guess the Renntech falsh riched out the A/F over time? Retuned itself? I can see the torque converter issue give you a few of hp more.
Old Oct 29, 2008 | 05:39 PM
  #202
MHP's Avatar
MHP
'09 C63 AMG
Originally Posted by JAYCL600
:b lah::bla h:
LOL Jay I hate to say it but all you do is run your mouth. You've made two 10 second passes in your CL600 and think you're some kind of God because of it? Is that the only car you've ever owned that's gone high high 10s or quicker? I sure hope not.
I would be greatly surprised if you acted the same way you do on the net in person, if so I'm sure we'll get along famously in a week and a half.
Old Oct 29, 2008 | 05:40 PM
  #203
MHP's Avatar
MHP
'09 C63 AMG
Originally Posted by RHBENZ
So why 2 different flashes? Can't you adjust the solenoid pressure and map in the same flash? Thanks for clearing that up.
Simple answer: No. It's not just line pressure we change there are far more variables.
Old Oct 29, 2008 | 05:41 PM
  #204
jangy's Avatar
2015 S212
I'd say that was a smart choice. Andy is much better at rationalizing anyday.
...all I know is what he has told me privately.
My point, exactly.
Mine? Are you sure? It is a mighty slippery slope on which you tread.
Again, that is noise. Would you jump off a bridge if he said he modded your shoes? There were no gains!! It was all RENNTECH!
HAHAH!! I am lost, but as per Andy's words the TCU gains would NOT be noted on a dyno. But now they are. Again, slippery slope. Yeah, I am the moron. But why is it getting so lonely over there?
To be clear
Fact: All HP numbers are derived from TQ numbers.
Fact: Andy has stated that the dyno would not show his gains.
Fact: Andy claimed TQ gains from TCU gains alone (since ECU did not take).
My simple question is this. IF MHP is removing TQ limiting obstacles that reside in the TCU (as claimed in prior threads), why would the removal NOT be seen on a dyno? If that was a misunderstanding and it is seen on a dyno, then why are there NO power gains associated with the delimiting? You take the governor off a lawnmower and it doesn't just have more grunt. It runs stronger!!
  #205
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
Originally Posted by MHP
I guess this test inadvertantly displayed what a TCU flash alone can do for power on a dyno.
Hope that clears it up for you, Jangy.
Andy - if that is in fact the case, that's pretty impressive and would explain the torque gains. However, I'm interested to hear your thoughts about just exactly which ECU tune was dynoed if yours didn't load - had to be the previously loaded Renntech file, right ??
Old Oct 29, 2008 | 05:42 PM
  #206
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
so first jim's ecu quits working right after an mhp flash, now this one didn't even take? WOW!?!?
Old Oct 29, 2008 | 05:44 PM
  #207
MHP's Avatar
MHP
'09 C63 AMG
Originally Posted by jangy
Looks like it. So, before the numbers were tru and higher and now they are simply noise of two various runs. Before, your TCU mod didn't show up on the dyno and now they do. Before TCU mods meant MODDING the TCU and now they don't. Boy how things change.
"Noise"? LMAO. We inadvertantly got to see TCU only gains on the dyno--honestly, we didn't think they'd show except for a bit of torque but I guess we were wrong. At least we'll admit said facts, and again, I find it funny you're trying to spin this situation into a failure. We just proved that we can make more power than Renntech with a TCU flash alone.
So to be clear, are you saying that you can mod the TCU module by modding the ECU module and having it later mod the TCU AFTER the ECU has been replaced? Can you mod the TCU or not and if so, lets see it!!
The only way TCUs are done in 63s is via the ECU--do you read anyone else's posts or just keep hitting the submit reply button as I've been over this dozens of times already.
Seriously, I just don't get how you can get things so twisted in that little head of yours. Jeff already has a TCU from us, which is why his shifting is so improved (again read his comments, jrcarts, vadert's, tuningtech's etc. for more TCU commentary) his ECU flash didn't take.
  #208
jangy's Avatar
2015 S212
Yeah dude, it is clear. Bye......
Old Oct 29, 2008 | 05:45 PM
  #209
MHP's Avatar
MHP
'09 C63 AMG
Dude I really think you have a reading comprehension problem....Is English your first language ???
It has been discussed before that the TCU stays in the car. The ECU is removed and then flashed - Jeff just said the ECU is takes 2 seperate flashes. One for the ECU tuning itself and one for the TCU. Of course, once the ECU is reinstalled it then communicates with the TCU and changes how it operates. What, did you think the TCU was flashed by osmosis ???
Ding Ding Ding. We have a winner.
Old Oct 29, 2008 | 05:47 PM
  #210
MHP's Avatar
MHP
'09 C63 AMG
Now I am really confused, since I was pretty specific with Andy when he first came on here to the point of literally asking for TCU photos showing that the tranny was openned. He didn't feel the need to prove anything to me and now you say it CAN be done through the ECU. Are you saying that is how MHP does it? Are you sure that works when all you have to mod is an ECU?
Yep all 63 TCU tuning is done via the ECU. When I first came on this site I posted that you needed to remove the TCU from the valvebody of the 7A to do a TCU on a 63 for a reason. The fact that NO ONE called me out on that told me a lot about where other tuners were with 63 ECU/TCUs.
...and for the record, I still don't feel the need to prove anything to you.
Old Oct 29, 2008 | 05:49 PM
  #211
MHP's Avatar
MHP
'09 C63 AMG
That's what I thought too.
PC can modify shift points on a 63? Show me.
TCU mods for a 63 entail line pressure changes, stall speed changes, Torque management elimination/reduction, shift quickness/firmness, heightened throttle response, etc. There are quite a few variables we manipulate.
Old Oct 29, 2008 | 05:50 PM
  #212
RHBENZ's Avatar
I don't doubt that there are more variables involved. It's your trade secret; you're the only one who offers it. You can charge for it. I'm not understanding the twice thing.
I'd better stop, my post count is going up...
Old Oct 29, 2008 | 05:51 PM
  #213
MHP's Avatar
MHP
'09 C63 AMG
Honestly? I am believing less and less that it is flashed. Again, inputs may be shifted but I do not believe that the code within the TCU has changed one bit. Adaptations may get reset, if anything. That is what I believe
www.theflatearthsociety.org
Just keep ignoring the data/results and concentrate on getting your car back together and running as it should.
  #214
jangy's Avatar
2015 S212
WOW, a WHOPPING 1% increase with your mod. Let me remember that one. It is noise, Andy. That low of gains from a straight mod is shameful. At least before, you claimed that the benefits of the TCU couldn't be seen by dyno and that you were able to match or slightly beat RT's ECU tune. Now, you say that those "gains" are from a mod that costs money? So, are you saying that this is the first time you ever modded just TCU in a 63?
Jeff, jrcarts, vadert's, tuningtech's etc. for more TCU commentary.
That's it? Only your homeys? Why not some feedback from a MEMBER here that is believed?
If you want commentary about my tunes, please contact my father, mother, brother, sister, etc.
Old Oct 29, 2008 | 05:52 PM
  #215
chiromikey's Avatar
you got us you sneaky rascal! seriously, does ANYONE still believe anything this guy says!!!!
Old Oct 29, 2008 | 05:53 PM
  #216
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Maybe....or maybe they are far less adversarial than you are in an open forum. Not saying they wouldn't trash you on the phones to potential customers... just seems other tuners are less apt to do come into YOUR thread and post stuff.
Tom
  #217
MHP's Avatar
MHP
'09 C63 AMG
No I don't, but I think the ECU / TCU need to be on the car for this to go. What you are talking about would simply be ECU parameters. For the 1000th time, this is not a new thing. If they are modding the ECU, then it is an ECU mod. The same way that an ECU mod can control throttle position, it can control some parameters in the tranny. That does not mean it is any more of a TCU mod than it is a TB mod.
LMAO, because line pressure changes, increasing stall speed, further reducing eliminating TM in TCU only code, quickening shifts (up and down) are things that ECUs do...Not so much.
Old Oct 29, 2008 | 05:54 PM
  #218
jangy's Avatar
2015 S212
Thanks for worrying about my car, but nobody is paying to see it run. Keep ignoring the data, results. How about you summarize the data and results and also do you fancy hp/$ or even TQ/$ now. You already got the sheep. Herd on.
  #219
RHBENZ's Avatar
I guess I'll add one more post.
Show you? I'm sensing a little hostility, but I'll let it pass since I'm not looking for a fight. I only meant that I thought you actually flash the TCU directly.
Old Oct 29, 2008 | 05:55 PM
  #220
MHP's Avatar
MHP
'09 C63 AMG
Now, you state that all one has to do is send in their ECU for a ECU AND TCU mod. We'll see if that is even possible, much less true. As has been stated many times before, many of the parameters within the ECU can have an effect on how other modules react. And yes, it takes a few hundred miles (closer to 500) for enough adaptation data to get stored for crisper communication but what does that have to do with changing the actual code on the TCU?
In all seriousness, you should be banned for posting misinformation.
ps--we severely reduce adaptive learning, to the point it's nearly irrelevant.
Old Oct 29, 2008 | 05:57 PM
  #221
jangy's Avatar
2015 S212
Huh? have you lost it now? Isn't the tuning done through the ECU on the 63 or not? Take your time and come up with a good one. This one may sting just a bit.
Old Oct 29, 2008 | 05:59 PM
  #222
jangy's Avatar
2015 S212
How is a simple question, that you have chosen to run from for more than a month, considered misinformation?
So what? I am not the one that wants it gone. Moe does. I like adaptive, but then again I like myMB.
  #223
MHP's Avatar
MHP
'09 C63 AMG
Originally Posted by Andy0331
From this thread: https://mbworld.org/forums/showpost....&postcount=449
No flames intended, but clarification would be nice. Before, the TCU had to be physically flashed (via new unit or sending in your factory one), now it is all done through the ECU? Please detail the process for each car or tranny.
As I posted a few minutes ago. All 63 TCU is handled via the ECU only, cars with WA5A variants are done via seperate control units as in we need both.
As for the quoted post above, do you have any idea how many other vendors with 63 tuning of their own called me out on that? LOL, exactly Zero.
Members/customers that PM'd me for more info on our 63 tuning back then were told about the ECU doing everything.
It's a shady business, we knew that coming in, and we still underestimated what some will do in an attempt to copy our tuning.
Old Oct 29, 2008 | 06:01 PM
  #224
TMC M5's Avatar
This is actually a pretty good question. Why did the A/F ratio change if the MHP ECU flash didn't take?
Tom
Old Oct 29, 2008 | 06:02 PM
  #225
chiromikey's Avatar
So if the MHP ECU flash didn't take, why the dif in A/F?...
lol, anyone going to answer this?
