Just purchased a 05 e55 and a message came on today about resetting the tire pressure monitor visit workshop.
Can I reset it myself or take it in to the dealer?
The car is still under factory warranty, so I'm not worried about taking it in, just wondering if I can do it myself.
If it displays visit workshop, than most likely there is a fault in the system.
You can try to reset it yourself. Check all your tire pressure and adjust as needed. Pressure chart is on the inside of your fuel door. Start the car scroll up to the tire pressure warning and press the reset button on your instrument cluster. It should as you if you want to set current tire pressures. Press the "+" button on your steering wheel to confirm. If that does not work there is a fault in the system and you will have to bring it in to the dealer.
Just tried it, no go. guess it has to go in to the dealer. oh well. Thank you for your help.
