Forged, Titanium Engine Parts upgrade advice?
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Since the W211 AMG section is the most mod heavy here...
I am considering the following and need any advice I can get...
Forged vs. Cast Pistons - Any major difference?
Best brand for MB? Manley or CP or other...
Titanium vs. 4340 Steel Connecting Rods - Differences? Titanium worth it?
Best brand for MB? Pauter, Manley or other
Titanium oversized 1mm Intake & Exhaust Valves - Worth it?
Best brand for MB? Ferrera or other
If there are any tuner/engine upgrade shops that can give me a quote, I am ready to start the project today.
I am also considering boring out my 5.5litre to a 6.1litre like Brabus does for C55s but the cost has too be much less than Brabus. This displacment increase must also be compatible with my Kleemann SC and two Garrett twin turbos. The drivetrain would also need to be upgraded to at least Maybach Guard Specs. Please PM me if you can do it complete with ECU/TCU tuning.
none
Robert, your starting to sound like my girlfriend chosing an outfit. Every week it's something new my man!
Keep it simple, your car is awesome. I would spend some effort getting everything running perfect and safe, then enjoy your "faster than 90% of the rest" C55. Which it probably is. If your looking for record speed keep the C55 as a daily, and buy a TTV12 platform car. I've already accepted the fate of my C43s power and started saving for a 600 or 65 car next year. Keeping the 43 though..similar thing though, for what it would cost me to get my C43 where I want it I can buy a CL600 and still have an interesting C43.
Mahle pistons are very nice for the record. You want forged. Lastly I don't think you need to got the extra effort of increasing valves and such at this point.
Happy thanksgiving.
Happy thanksgiving.
1 Post
Happy thanksgiving.
Happy thanksgiving.
I'm still going to pick up a 2006 SL65 when it drops to around $50K but just enjoy hacking this car as a hobby and learning experience.
2015 S212
Forged is the only way to go. I have no clue what advantages a cast one would have so I am confused if it is even available.
The rest, it really depends on what is worth it to you and what your goal is with your car.
How is your car running now? I haven't kept up with it so I dunno where you are now. I didn't even know you had added 2 turbos. If the car is healthy (as in repaired), then are you sure you want to get into the bottom again? What is the goal and what are the gains?
As far as doing a full on 6.1 bore out, I'd find it very interesting as long as you understand that you are going even farther out on the ledge. Have you considered a new C63? Just a thought, since it is a 6.2l. If you love your platform then consider looking at what the others have done with your drivetrain to get some serious power. Make sure you aren't just being unique but also productive. Not talking trash, but make sure all of your exotic mods can beat the pants off of any other N/A 55. Ahmad's 208 CLK55 just ran numbers comparable to a stage 5 E55. He has a butt load of mods that may be a stronger bang for the buck than titanium fittings.
1 Post
As for Ahmad's blackbenzz, Congrats to him on having basically the same setup as mine minus the cams and air vents in the headlights. He's running 8psi just like me. The goals for my exotic mods will be possibly 8's 1/4 as it will be a full-on race car with close to 1000hp.
Wait a second, you want two GT turbos and the kleemann sc? Wow, you have very high goals my friend. Forged is the only way to go internally. I have a built trans from Southern Hot Rod and so far it has done its job well
Why bore it to 6.1L? You dont want thin cylinder walls if you want to make high boost. Your goal of going 8's is a HUGE undertaking. I would build the engine and put two turbos (take off the charger). Making the power is just the beginning of going 8's. You have to make SERIOUS power to go 8's and have to be able to put it to the ground.
1 Post
none
Last year I almost yanked my mill for a build up and swap the SC for a centrifi and alot of boost. I was at the same point in terms of what bore. We were going to use my 4.3 block instead of swapping a factory 5.5. We were going to bore out to about 5.0L or so to keep a good amount of meat between the cylinders oposed to boring all out and having the neighbors living too close. I think the C36 turbo kits fail alot due to close and thin cylinder walls.
2015 S212
I would never consider a C63. They are 12:1 CR. You can't even supercharge them as is. You would have to hack it just as I've hacked my C55 already.
I agree with some of that. I am one that believes all the 63 needs is a little drop in CR and a little boost to add an easy 100rwhp. Also, if you are getting new pistons anyways, then the CR isn't really an issue. I just threw it out there as a suggestion with the assumption that you would also mod it. I just thought it was already large displacement with stronger internals.
Last thing, if you are serious about even 9s and 1000hp then make sure to plan it all out ahead of time. No disrespect meant, but your setup is simply not going to pull that type of performance numbers on random mods alone and the Brabus build isn't really representative of what you are doing since the only thing in common is a bore out to 6.1. Brabus dumped a bunch of money into that setup to build a name. I'm not saying that you can't do it. I am saying that Brabus' intention was never to build a true performance beast. It was to sell hardware and not the parts that made up the Brabus 6.1. If you attempt a cheap copy, you will likely fall short since they actually spent a pretty penny to get it done as well. Point being, they were not charging themselves the Brabus MB tax and still spent a load.
Either way, not trying to derail you. Honestly, your journey has been an interesting one for many here and we have also learned. I'm actually all for you taking this on and letting us know how it is going, but I want to make
sure that you understand the playing field this time. I hate to see a mod head get frustrated in the middle of a build for any reason and the last 2 times with you have been tough for the tuners and you. That is honestly why i tried to say C63. I wanted your car gone!! HAHA!! Goodluck in whatever you try....
The limiting factor for the blown 55s is not bottom end displacement, just as with any other FI app it's the size of the blower that ultimately determines how much hp/tq you can make. Forget sleeving, you're just compromising the integrity of the OEM design for a few inches that won't make a bit of difference.
You want 2618 forged pistons. CP and Diamond are two of the best to consider, we use CPs on all our builds. They aren't cheap but the quality and finish machining is immaculate.
As for rods you could probably get away with 4340 forged H beams from Manley, just make sure you upgrade to ARP 2000 7/16" rod bolts (instead of 3/8"). If you want to overbuild or see yourself turning 7k rpm or making 800rw+ then go with 4340 billet I beams from Manley. Why Manley over Oliver, Carillo, etc? Even though they all weigh within a few grams of each other manleys carry more mass in the big end of the rod (where all rods tend to oval over time), Olivers and Carillo's carry more mass in the neck of the rod--where no rod, even a 4340 forged H has ever failed on it's own accord hydralock notwithstanding.
Quality Ti valves are around $100 per valve, I would personally save the $, go with a nice stainless set and put the $ not spent on the valves into the bottom end. Forget Ti rods, they are also a waste of $ in this app and won't live nearly as long as a 4340 rod.
If you want you can PM or call me to further discuss your options.
Andy
614 940 9523
edit: Just saw that you plan on going with twins (if so, ditch the blower, it's just going to be a restriction) in which case you'll want inconel exhaust valves.
Yes we can also ECU/TCU tune your car.
Andy
614 940 9523
2015 S212
Hehe, I was gonna say you may be a good tester (for the board, not in life) for the MHP setup. No matter what you do, you will need ECU tuning. No matter. Also, you will need TCU. I hate to see the SC go, but just promise we will still see some bottom end grunt.
1 Post
Andy
614 940 9523
Andy
614 940 9523
You sound pretty knowledgable. I will give you a call soon.
sounds like airplane
what are you going to do to the chassis to run 8s?
I don't think you know what you are getting into...
I've followed multiple builds on bimmerforums on somewhat similar cars that resulted in those kind of numbers and the power isn't the issue. Notice that I don't even have personal experience and have only followed builds so I'm only smart enough to know what I don't know. $$$$ or $$$$$ or even $$$$$$ may not be all it takes.
Do we have a list of independent shops that can/will build and customize the m113 motors?
Received 1,065 Likes
E55, GLS450, GL63, GLE350
If the 6.1 can be sleeved successfully without tapping the water jackets then it would work just as the Brabus 6.1 C55s have worked. I would probably have to sell the Kleemann Twin-Screw when I put the extra large AAA sized turbos in. since the larger displacement will give me enough torque down low. Traction and drivetrain will also be modified with the engine.
Read this before letting anyone touch your engine. There are plenty of "tuners" that will do the wrong thing to your engine for a bunch of money. http://www.kolbenschmidt.com.tr/pdf/...804-02_WEB.pdf
1 Post
Sleeving the engine is a good idea for what you want to achieve but you have to make sure you deal with a company that has done this extensively. The cast iron sleeve will be stronger than aluminum and will fare much better under higher pressures that you would need to achieve your goals. The cast iron will not trumpet like an aluminum bore under very high pressure. It will also enable you to run any forged aluminum piston. Otherwise, you will need to run coated pistons that are compatable with an Alusil bore. The only coated pistons that I know will work in an Alusil engine are made by Mahle and Kolbenschmidt.
So is Alusil similar to the Nicasil coating that the AMG cylinders are lined with? I always wondered if getting the new bored out cylinders would need to be Nicasil coated. I found companies that do that on the net but don't know if it's needed or how much it would cost.
2008 A8L, 2002 996TT X50, 2009 X5
AMGSC, I look forward to following the latest evolution of your C55 build. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
That said, I do have one question regarding the "coming soon" section of your sig. - CF crank shaft? Never heard of that; did you mean "drive shaft"? They are different...
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
Thanks!!! Now this is the kind of advice I was waiting for along with Andy's and several other posts! Advice like this TRUELY demonstrates the INCREDIBLE VALUE of mbworld.com
1 Post
Thanks for straightening me out. So what is the coating on the M113 cylinder walls?
1 Post
You're right. typo. I meant Evosport's Carbon Fiber Drive Shaft soon to be released...for the C55
2005 Kleemann Stage 3 E55
Has anyone successfully done port work on the 5.5 heads with flow data and dyno numbers to back it up? I've been off these boards for a few years and would be interested to know. NO Assumptions. Just facts.
There are a few different options. You can run a resleeved engine with iron bore. Use pistons from Mahle or Koblenschmidt or use a custom coated piston. It's hard to find a custom aluminum piston with coating that has the proper expansion characteristics to work in the Alusil bore. You will spend much more for the pistons from Mahle or Koblenschmidt but it will be money well spent. The last option is to have the cylinder walls coated with a dissimilar surface as they did on the 63's M156 or BMW and Porsche did with the use of Nikasil.
