I Normal tire wear? 05 E55
Old Dec 2, 2008 | 09:44 PM
Friction's Avatar
05 E55
On an 05 E55, all four of my tires are wearing alot faster on the inside than on the outside. Is this normal? Dealer says so, but it does not seem right to me.
Old Dec 2, 2008 | 10:25 PM
Serenity Now's Avatar
03 E55 AMG
E55's are famous for needing alignments more frequently than "normal" cars. I'd have a reputable shop check your alignment. That would be my guess.
Old Dec 3, 2008 | 05:32 PM
D Bst's Avatar
2004 E55 AMG; 1995 Porsche 993 Cab.
Just went through this myself, had to replace a damn front tire as the front nearside camber was WAAAYYY out and had resulted in the inner edge wearing to the steel!
Had it checked out on a Hunter alignment machine and the guys had to install a new camber alignment bolt to push the camber figure from something like -2.5 to -1.5... (don't quote me ... I'm going from memory).
I've heard that the camber values are set form the factory to GERMAN high speed Autobahn settings, and not lower speed US highway values... so there is a lot of inner edge wear to the front tires... the backs should be uniform wear across the tire, but with all that torque and a lead foot they wear quicker... the rear nearside (right) tire will wear faster as it's the more "driven" wheel without an LSD.
a new aligment to a less "aggressive" front camber setting should help with wear, unless you are hitting a high speed track (probably not too likely) and need it set that way.
